cat prices?
Old Apr 10, 2001 | 10:57 PM
WS6Formula305's Avatar
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
cat prices?
how cheap (or expensive) would two high flow cats run me? ones that one crap out in two years.
quick explanation : talked to gearhead at our local good year about my exhaust... he wants to run the SLP headers straight to the cats (if they are long enough) and then run 3" pipes back to the muffler... true duals i suppose. he planned on running an "exchange pipe" i think he called right after the cats i think? i wasn't clear on that part. can i buy the SLP headers without the Y-pipe if i go this route?
thanks.
'88 WS6 Formula - Stock LB9
Old Apr 12, 2001 | 02:26 AM
FlashGTA
Guest
Posts: n/a
The exchange pipe he is talking about is a balance tube. Depending on it's location, length and size it affects torque and HP. If he has never dynoed a car he is guessing and if the pipes are running right next to each other you probably won't see a difference with or without the balance tube. I don't know how he's going to fit 2 3 inch pipes in there and over the rear axle, depending on what it's going to cost it might be cheaper to get a Mufflex system, like 3 1/2 inch for the future. Twin 3 inch pipes are way to big for your engine and is massive overkill and a waste of money. Even big blocks usually only need 2 1/2 duals.
Old Apr 12, 2001 | 04:45 PM
Dan87IROC-Z's Avatar
A catalytic converter can cost you anywhere from about $65 (Catco) to $220+ (Random Technology).
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
92firebirdguy
Sep 1, 2016 07:53 AM
mud runner
Nov 2, 2015 07:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
pimprs
Sep 10, 2015 03:34 PM
Stryker412
Sep 7, 2015 09:11 AM
