header debate
Old Apr 8, 2001 | 08:31 PM
NitroMac's Avatar
header debate
looking to put headers on my 86 Z28. what is a good brand to buy that is also fairly easy to install? emmisions is not a problem im in Iowa.
you can never have too much horsepower
Old Apr 8, 2001 | 10:30 PM
CamaroX84's Avatar
You should look into the Hooker Headers that come with the y-pipe. It has the spot for the O2 sensor as well. They are listed in JEG'S for $349.99, but I know Summit has them too. Just search for Hooker part number 2055. Not sure how easy they are to install, but this is the kind I am getting for my 350 I'm putting in. Hooker has been around for a long time and is a good brand. If you want stainless steel, I would try the SLP headers. Just my .02
Old Apr 8, 2001 | 11:01 PM
chevyboy07 91's Avatar
non AIR heddmans w/ y-pipe for $200 bucks. By an o2 sensor bung and weld it in AFTER you drop the hedder in so you know where to put it.
Old Apr 10, 2001 | 01:38 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
I am going to say slp. buy the ones without air fitting. they are alot nicer that headman or hooker. they have a nice thick flange and all pipes are seprate. I have not had a gasket blow out yet and only tightened them after the first warm up. I have had trouble with hookers and headmen on my chevelle and pickup. I would have ot make it a habbit to re-tighten or bolts would back off. so unless you like changing gaskets I would buy slp.
"I don't trust anything that bleads for five day's and doesn't die"
88 iroc slp headers,borla catback,procharger to come soon.
Old Apr 11, 2001 | 08:04 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
SLP all the way. Put mine on (1 3/4) and never re-tightened. No stage 8 bolts... spend that money on aluminum header gaskets and you will never have to worry about them blowing out or having your pipes rot away.
Old Apr 12, 2001 | 08:01 PM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
On the bottom end, I have $83 Flowtechs, no Y pipe, I have custom dual exhaust. O2 fitting only. The black paint did burn off and they are now rust color ugly,Other than that I'm pleased.
No emmisions here in NW Georgia
1986 Black/Gold LG4 Z28
Original Owner, 200,000+ near trouble free miles.
Mostly Stock.
1995 Dark Red Metallic Corvette Coupe Original Owner
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Bigold4x4
Sep 28, 2015 05:21 PM
