2 Hooker O2 Q's
Old Apr 10, 2001 | 04:10 PM
2thpick's Avatar
2 Hooker O2 Q's
I got a new oxygen sensor at the parts store the other day for my new headers. When I drilled out the hole for it in the headers and then tried to screw it in it didn't. The O2's threads didn't match up with the threads on the Header.
Is there a different one I have to get for the Hooker's? Do a need a heated O2.
1991 Camaro RS 305 5spd
-IROC Hood
-IROC Wheels
-IROC Grill
-Blue Neons
-Bowtie Foglights
-weight mod, empty engine compartment
1994 S10 2.2 5spd
-Dixie Horn, Air Horns, Knight Rider Lights, 162,000+ miles
http://www.geocities.com/david_somers
Old Apr 12, 2001 | 02:21 AM
FlashGTA
Guest
Posts: n/a
Mine screwed right in when I put Hookers on my 84. It was a stock single wire sensor.
Old Apr 12, 2001 | 04:04 PM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by FlashGTA:
Mine screwed right in when I put Hookers on my 84. It was a stock single wire sensor.</font>
I think his will screw in if he works on it a little with the dremel, the hole that was drilled looks like it's slightly off center.
Your car is carbed right? Have you noticed any ill effects using just the stock sensor?
[This message has been edited by Keith5 (edited April 12, 2001).]
Old Apr 13, 2001 | 01:01 AM
FlashGTA
Guest
Posts: n/a
The 84 runs like a champ, never had any problems and no trouble codes. I drilled my bung out then used a dremel to dress it up so you are probably right he just needs to clean it up.
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
