Terrible Exhaust leak and wierd smell?
Ok, here's my situation... ive been trying to piece together my girlfriends 87 bird. It's got a bad exhaust problem, the fumes get strong enough inside the car to make you lightheaded, windows up or down. The other night while test driving i also noticed what smelled like flowers?! This car makes less sense all the time. =) I havent found any obvious exhaust leaks and the catback is new with welded seams. Could this be at all related to a plugged converter, as it does rattle a bit. Any thoughts?
Thanks in advance....
<font face="Verdana, Arial" size="2">The other night while test driving i also noticed what smelled like flowers?! This car makes less sense all the time</font>
If you haven't by now, definently check into the catalytic converter. Fumes getting into the passenger compartment are not good. Also check into the Exhaust manifold gaskets.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance Soon: Edlebrock Intake & TES
Hotrodboba400
12-10-2019 07:07 PM
