Whats the best exhaust? What are the best headers?
#201
Re: Whats the best exhaust? What are the best headers?
Go with the Heddmans for sure! I just installed Hooker ceramic coated hedders and y pipe on my 86 Iroc and nothing fit proper! I had to beat/dent 3 tubes on the hedder just to get the bolts in the flange holes they were so bad and the y pipe was off center by 11/16" from bolting up! I had to measure the y pipe and take it to my fab guy cut it in half and take 11/16" out of the middle for it to fit! Hooker sucks, it was my first time using them and for $700 total I will be going back to heddmans stuff. Not to mention the "ball and socket" flanges from heddman never leak and don't even use a gasket! Good luck man!
#202
Car: 85 Z28
Engine: For now 305
Transmission: For now 700R4
Axle/Gears: Stock 3.23 for now
#203
I have hooker headers on my Camaro. Corvette style and they fit just fine! I am sorry you had trouble with yours, but, I have had no fitment issues whatsoever. The y-pipe fit great although we did end up cutting the end off and welding a flange to it to bolt up to my converter. Again no troubles. On top of that I got them JET-HOT Coated and they look outstanding! It also cut my engine bay temps in almost half!!! Their is awesome!
YES, there is a system for dual exhaust for a thirdgen f-body. I have an article in one of my magazines where they did it on a Trans Am. They used long tube headers and a corvettes style exhaust where the pipes ran along underneath the driveshaft. I will look it up and post the info on the artcile as soon as possible. It was either Super Chevy OR Camaro Performers OR GM HighTech Performance.
Through talking with lots of long time mechanics and exhaust fabricators, this seems to be the only way to do it. Ive been told by numerous guys that it just doesn't work. Although I thought I saw once that 1LE Camaro's had TRUE dual exhaust with four converters.
Anyway... these are just my thoughts based on experience and research. I will post the article ASAP. Look forward to hearing your thoughts!
#205
Car: 85 z28
Engine: 410 CI
Transmission: 700 r4
Axle/Gears: 373
Exaust
Hey all im new to the fourm and i just have a quick question and need some opinions here it is i have an 85 z28 with a pretty angry little 355 my current exaust is straight pipe out of some shortie hedman headers 1 5/8 inch and im looking for some tone and still maintain my power any suggestions thank you so so much
#206
Car: 1986 Pontiac Firebird
Engine: 2.8 V6
Transmission: 5 spd
do they make any headers for the 2.8? if so what n where can i get em?
#207
1 Post
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
I think they have headers for the 2.8L on Hawks Third Gen or Youngs THird gen parts. Just google it.
#209
Car: 91 Camaro RS
Engine: LO3, 305 TBI
Axle/Gears: 3. something low. like .14 maybe.
Hey guys i just got dual exhaust for christmas. It is Dynomax i believe. how good is that compared to magna flow or flowmaster cause dynomax is like half the price for dual.. thx
#211
I read the post and i am still a little confused what should i look for if i am running a crossfire set up on an 83 Z28. Please note that i plan on installing a renegade manifold in the near future as well as a COMP CAMs TBI/Crossfire cam. any advice is appreciated
#212
Car: 87 IROC
Does anybody have any dyno #s for the 2055s before and after and what about the edelbrock 68723s no one even mentions them are they that bad
#213
Car: 1992 Firebird Formula T-Top
Engine: 5.7 TPI
Transmission: TH700-R4
Which ones are u talking about i found two different kinds of Hooker 2055?
http://www.summitracing.com/parts/HOK-2055-1HKR/ or
http://search.yahoo.com/r/_ylt=A0oG7.../2055/10002/-1 Please Help
I'm gonna chime in and say that I think the Hooker 2055 headers are the best out there period! I know I'm gonna get a lot of crap for saying that because it seems that everyone believes the SLP's are the best. It seems to me the only advantage the SLP's have are they are stainless steel, but that doesnt matter if you get the headers coated. The Hookers have 1 5/8 inch primaries which are just fine for anything making less than the 450 hp range. The hookers also have a 3 inch collector which does neck down to a tiny 1.9 inches at the ball flange, but that problem can easily be fixed by opening that up to the ID of the y pipe. The SLP's only have a 2 1/2 inch collector that necks down inside. I have heard many horror stories about the SLP's fitment and a lot of work needs to be done for them to fit right, whereas the hookers fit nicely with no modifications. Now comes the sweetness of the 2055's; the awesome y pipe! The hooker y pipe is by far the best y pipe available for the third gen f body, it is a work of art! It has nice 2 1/2 inch mandrel bent pipes that come together in an awesome 3 inch collector all the way to where the cat mates to the y pipe compared to the SLP y pipe that only has 2 1/4 piping.. The hooker y pipe doesnt stick out in the wheel well like the SLP y pipe does either. Now another strength of the hookers are they are wayyyyyyyyy cheaper than the inferior SLP's. I have done extensive research on all the brands of headers and have found that the Hooker 2055 headers are by far the best headers available!
#214
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
SLP's are better than Hookers. You can not get 1 3/4in tubes in no other shorty brand but SLP's. The only set of headers that are better than SLP is Dyno Don's. His headers are 1 3/4in tubes with dual 2 1/2in cat and 2 1/2in y-pipe into 3in cat.
These are SLP
These are SLP
#215
1 Post
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: 3.43
is it worth getting the dual cats, my main concern is if I get them will it be difficult to get headers installed later. How I am supposed to keep the air tubes if all the headers do not have the holes for them?
#216
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
FYI
This is a Email I got from DynoMax about the Dual system #89009
http://www.summitracing.com/parts/WLK-89009/
P.S. Search for part numbers at Advance Auto use code P20 and get 20% off everything!!
Thank you for your inquiry for Walker Exhaust. We appreciate your interest
in our products.
Dynomax Performance Exhaust: Email the Dynomax Tech
Email: johnnygeek@hotmail.com
Time Zone: EST
Best Time to Call: 10am
Make: Pontaic
Model: Formula
Year: 1988
Engine Size: 5.7L
Displacement: 350cc
Transmission Type: auto
Wheelbase: 101"
Doors: 2
Drive-Line Type: 2WD
Quesiton / Comment : Purchased exhuast dual system #89009 I have not found
a set of headers #85012 that are required to fit
I can take my car to a muffler shop to attach your system to the wrong
headers #11102FLT
not happy but it will work
is there any other part numbers,for headers, that fit that dual system?
unfortunately we don't offer headers anymore.
If you have any further questions, please feel free to contact our tech
line at the number below.
Thank You,
Humberto Oviedo
Humberto Oviedo
Walker Exhaust
Installation Technician
WOW I sent a hate/anger/rage reply.
in our products.
Time Zone: EST
Make: Pontaic
Model: Formula
Year: 1988
Engine Size: 5.7L
Displacement: 350cc
Wheelbase: 101"
Doors: 2
headers #11102FLT
Thank You,
Humberto Oviedo
Humberto Oviedo
Walker Exhaust
#217
When I bought mine it had Hooker headers with what looked like a homemade 3 inch straight thru exhaust, so you know it sounded loud. I put a hi flow cat on it and magnaflow cat back, but it dulled the sound way too much. So I went with a flowmaster 44 which is the loudest street leagl muffler they make and 2.5 inch pipes. It is almost as loud as it was with the straight thru exhaust but now is legal. I think SLP with its ludmouth exhaust is the closest thing. But, I don't know if they consider resonators as mufflers.
#218
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you think 2055's are the best, then you haven't seen these:
#219
have any of you guys noticed the super small collectors on the hooker 2055's?? Not sure if they were changed or not but the diameter of the hole at the collector "ball" flange was only 1.94" on my setup!!! This was back in 05-06. Thats good for smaller milder motors but not something with decent amount of horsepower.
I was able to port that setup to 2.25" comfortably and still have good seal to the ball/socket flange.
Also, if you guys use larger heads like AFR 195's with the larger exhaust ports, the hooker 2055's will not cover the port. 1 5/8" is too small. In fact anyones 1 5/8" is to small. Some argue this doesnt really matter since most of the exhaust stream comes out the center of the port, but in chasing every last pony, I'd want a header that covers the port and leaves NO step in the exhaust path.
Hooker Y pipe is fine but hung alittle lower than I would have liked.
Dyno don's are gorgeous and proven to make power on even wild setups. Not much if any loss on power compared to longtubes. They are likely the best header for these cars for most street/strip builds when you factor in fitment, cost, power potential, and clearance.
#220
FYI
in our products.
Phone Number: 3867859382
Time Zone: EST
Make: Pontaic
Model: Formula
Year: 1988
Engine Size: 5.7L
Displacement: 350cc
Wheelbase: 101"
Doors: 2
headers #11102FLT
Thank You,
Humberto Oviedo
Humberto Oviedo
Walker Exhaust
in our products.
Time Zone: EST
Make: Pontaic
Model: Formula
Year: 1988
Engine Size: 5.7L
Displacement: 350cc
Wheelbase: 101"
Doors: 2
headers #11102FLT
Thank You,
Humberto Oviedo
Humberto Oviedo
Walker Exhaust
so what did they say after to your reply?
so how will you install the exahust?
#221
I have a 1982 z28 with a 350 instead of a 305 (doesn't matter anyways) but i'm having an exhaust problem. I just have two straight pipes leading to flowmasters and i'm having a terrible clearance problem. I want to replace the whole system and i'm not sure what kind of headers to get or if I should go back to manifolds. I'm also not sure what kind of muffler(s) to put on it as well. the most important thing to me is the distance between the ground and the exhaust system itself. If I have to sacrifice some rumble thats fine with me but if someone could please help me out with this it would be appreciated. It does have a carb by the way. Thanks.
#222
1 Post
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
My brother just ditched his stock exhaust and got Hooker 2055 Headers. They woke his car right up. So that being said, don't go back to stock manifolds! They are the biggest bottle neck out cars have. I am saving up for Dyno Don's headers. Everyone seems to love them and his service.
I bought the magnaflow dirrect fit dual cat system for my car and it goes in the stock locations really tight up to the body. I'm really really happy with it.
My brother bought the American thunder cat back system for a 1991 Camaro. and I am jealous of it. Went in really easily and sounds really really good. Its quiet enough at cruising rpms and really opens up when you hop on it.
Hopefully this helps you get started.
#224
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Hooker 2210s for SBC/LT, Hawks for LSX.
While the Hooker 2210s are the best performance the Hedman 68460s are better in clearance.
#225
Car: 87 formula
Engine: LG4
I have mac's to a highflow cat directly to a flow master resonater connected to the stock over the axle pipe to 40 series flowmaster single in dual out.
Sounds mean and awsome
any advice
My idea's
a) lose the stock over the axle pipe for somthing better
b) lose the muffler (dump behind passanger rear tire)
c) lose a and b (pipe out in front of rear passenger
e) just leave it
d) a possible better idea
any advice
My idea's
e) just leave it
#227
What size primary tubes should I have on a 406cid small block? The headers will be long tubes and the motor makes about 400 to 450hp. I might shoot 100hp to it in the future.
#228
1 Post
Car: 82 camaro Z28 Indy500
Anyone tryed the Hooker Headers 2460-2HKR?
Runing the dynomax shorty headers (out of production) with a fully custom made exhaust system, made a custom y-pipe over to the oval nascar pipes to save som clearence. Need some new headers in stainless steel like the rest of the exhaust, and don't want to build a new y-pipe, it was a pain! Wondering if anyone had a clue if there are som headers out there that would fit right in?
#229
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Longtubes vs shorties? I run shorties on my 4x4 trucks but longtubes would be better for my F-Body application? Hedman 68460s bolt on without modifications to any components? Spark plug angles?
#230
1 Post
Engine: LB9 305 tpi
Axle/Gears: 3.43
I wonder is it worth it getting, long tube headers or since I live in california is it better if I get smog legal shorty headers since they seem to be the only type to be smog legal. how much better do long tubes flow.
#231
i have a dual cat 350 trans am gta 1991. can i run the hooker 2460 and y pipe and use single cat components on this car. i have upgraded engine cam heads tune. has anyone used hooker long tubes and off road y pipe? do either get in way of subframe connectors or the torque arm with the long tubes? any help would be great
#232
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Dyno Don's and a Classic Chambered Powerstick. 3" all the way back, no cat.
http://www.youtube.com/watch?v=MPVV21C1n88
#233
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
I have a question, will these headers (http://www.summitracing.com/parts/HED-68470/) work well with this Y-pipe (http://www.summitracing.com/parts/HED-17478/)? And will they bolt up to the existing exhaust on my 86 z28
#234
Sorry for jumping into this thread, but could someone tell me what shape gaskets I need for a stock 1985 TPI 305? I am putting on some headers and want to order copper gaskets, but I am not sure if I need round, square or oblong ones and the part store has no clue. I just wanted to get the gaskets before I rip my Camaro apart. Any help would be greatly appreciated. Thanks in advance.
#235
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
I need a new CAT
And best exhaust for a 3.1 v6
Looking for best fuel economy don't care about HP.
I heard Y pipe 2.5 or 3 is good
Anyone have a link to a complete set up??
With a Cat
With a Cat
#236
I have the stock exhaust on my 87 GTA, I am looking at the Cat-back Magnaflow 3", When listening to them on youtube they kind of all sound different depending on the camera. I was just wondering if there is a big difference between the stock exhaust and the magnaflow. I find the stock exhaust a bit quiet. Thanks.
#237
Car: 1991 Z28, 350TPI and 1977 Trans Am
Engine: 5.7
Transmission: auto
I need help! I recently changed my engine and upgrade the exhaust by removing the stock exhaust manifold for Headman Headers. I have had nothing but trouble ever since!!! they will not stay tight, keep coming loose and of course its ussually the right side that loosens up. i have replace the bolts and used lock tight. this will be my fourth time with less than 2000 mile on the new engine that i have to tighten these bolts. Does anyone have any recommendations? otherwise i an removing these pipes and going back to original.
#238
Engine: 5.7
Transmission: auto
from what i have learned you will need to look at the head exhaust ports to see if they are round or square. also your headers are most likely round so if your head exhaust ports are square you will have leak issues. pull your headers back first to see what shape your head exhaust ports are first.
#239
https://www.thirdgen.org/forums/group-purchases/672172-group-purchase-1-5-a.html
http://madhammer.com/pages/mad_hammer_prod_82-02_cama.html
Here is two links to the Headers and exhaust that I will be using on my 89 Iroc that I am in the middle of a LS1 swap right now. This is some of the best flowing best sounding exhaust out there and it's stainless. The headers are desighned for third gen LS1 swap.
#242
Car: 1990 camaro rs
Engine: 350 TBI
Transmission: auto
wow I just wanted a quick reference on the topic... someone should go through this and delete alota post... way too long.. its like a never ending soap opera.. and I still don't know what is good and what aint
#244
Car: SilveradoCamaroChargerHarley
Engine: 6.2/5.7/5.7
Axle/Gears: 3.42/3.40/3.28
My .02, I had headmenn long tube headers and I did not like them. I think I spent more money on gaskets than I did the headers trying to eliminate leaks. A bolt hole near the middle was slightly off almost ruined the threads on the head. I'm trying to remember but on the driver side, 3 bolts going towards the aft I couldnt install the spark plug. So anytime you need to change the plugs you have to pull back the header. Also, you have to get creative with the spark plug wire routing, though this might be common across all after market headers. If I did it again I'd try something different and definitely go ceramic. My trucks ceramic headers look amazing going on 3 years now. The headmen headers paint rusted out within 6 months in Hawaii.
Also I would suggest going with a mini starter. It'll make life so much more easier.
#245
Car: 91 G92 Z28
Axle/Gears: 342
Can anyone here comment on Jet Hot coated vs factory coated headers by manufacturers like Hooker? Is one better than the other? Are they coated inside and out?
#250
Car: 1987 Z28 zz440
Engine: ZZ440
Transmission: 5spd
Axle/Gears: 4:11
I have a 87 Z28 with full frame extensions and cross braces. It has a ZZ430 350. Right now I have a severe vibration caused by long tube hookers hitting the K frame because of the 4 tubes(right at the brake line on the passenger side) bought it like that. Anyway was doing research on shorty headers and was surprised to find so many posts about emissions. I live in Rhode Island and emissions and inspections are not required on any vehicle older than 25 years old. Also it is registered as a "historic vehicle" so I don't have to pay yearly taxes, save on registration fees and cheap insurance. My question is what shorties are the biggest tube and that would come with a matching large tube "Y" pipe to connect to the 3" pipe to the rear ( which runs down the driveshaft hump because of frame connectors I can't go under the passenger seat. Due to the Lowered frame/suspension I can't put duals to the rear. Ricks has shorties but they have very restrictive bends. Would love to find headers with at least 1 3/4" runners to match the aluminum heads. Appreciate the input, Anybody need my hooker long tubes? lol
