hedman x-tensions?
Old Jan 8, 2003 | 12:48 PM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
hedman x-tensions?
anybody know if those hedman universal x-tensions will clear the crossmember for the tranny? ive got full length hedman hedders and i want to run dumps w/ bullet mufflers
thanks
Old Jan 8, 2003 | 01:47 PM
Momar's Avatar
Actually that is what people have been using lately with the hedman headers to clear the crossmember. I have hookers so mine could have cleared the subframe/crossmember, but I am using the s extensions to move it to the center by the drive shaft tunel. Here is a link to a rough sketch of my exhaust and a problem I am currently having. The passenger side fits perfect, but the drivers side header aims back at a slight angle toward the center of the car so it is throwing of my pipe routing. https://www.thirdgen.org/techbb2/sho...postid=1081421
Ben
Old May 16, 2003 | 11:43 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Pic included
Hey I just wanted some type of input on mine. I installed them today and they seem to be right on the ground. I was expecting some ground issues but not as much as they are. Anyone who has the extensions please reply and tell me about your ground clearance. Thanks
They are lower than they look in the pic.
Old May 16, 2003 | 11:44 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Last
Old May 16, 2003 | 12:21 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
yep
mine did the same thing.. yeah it cleared the crossmember but it still comes down further than needed........
i am going to buy some flex pipe and do away with collectors all together
Old May 16, 2003 | 02:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can't tell from the picture, but can't you rotate them towards each other?
Old May 16, 2003 | 04:15 PM
Momar's Avatar
I have hooker headers so I didnt need to come down as much as you guys do, but you can rotate them. I just turned mine most the way sidways and it has about 5" of ground clearance now that I got the clamps off and have it welded.
Ben
Old May 16, 2003 | 04:16 PM
Momar's Avatar
Also, in my case, by turning them sideways, it put them right in the edge of the driveshaft tunnel so they tucked up real nice in back too.
Ben
Old May 17, 2003 | 08:48 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
I can turn mine but it doesnt make much of a difference. Ill experiment a little bit later and come back here.
Old May 20, 2003 | 08:05 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Momar, if you wouldn't mind could you tell me all of the pieces that your exhaust exists of. Did you have to modify your h pipe at all?
Old May 20, 2003 | 08:13 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
I searched it and now my only question is how much did the h pipe cost?
Old May 20, 2003 | 08:20 PM
Momar's Avatar
Hooker long tubes, s extensions, summit aluminized h pipe, 2 4' pieces of summit alumized pipe, bullet mufflers and turndowns.
Here is a link to the H pipe. http://store.summitracing.com/defaul...2025&x=14&y=16 It is part number SUM-642025 on summit if the link doesnt work. It was 36.95.
Ben
Old May 20, 2003 | 08:22 PM
Momar's Avatar
Oh, and for the h pipe, the only thing I modified was the lenght of the pipe in the middle. I just cut it down so that it was short enough to fit and then slid it all together, aligned it how I wanted it, clamped it and took it to the exhaust shop.
Ben
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
I apprecaite it.
Old May 20, 2003 | 08:29 PM
Momar's Avatar
Not a problem. You have the hedman headers right? I had to modify my s extension on mine because the drivers side collector on my hookers didnt aim straight back. I just cut a pie shape out of it and had it heated and bent and welded. I did this and it still kept it the same diameter inside instead of having it bent and squashed down real small.
Ben
Old May 20, 2003 | 08:42 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Why did it not aim straight back, was it because you had to turn them it what? My passenger side is a little turned in.
Old May 20, 2003 | 08:46 PM
Momar's Avatar
It was actually the flange on the header that didnt aim straight back. At first I thought that my extension was messed up, but I tried the one from the other side that aimed back perfect on it and it was crooked and the one that was messed up origionally was straight on the passenger side. It was nothing to do with the extensions, but just that the one header didnt aim perfectly straight back. I just corrected the angle problem with the extension.
Ben
Old May 20, 2003 | 09:00 PM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
Ahh I see, well I'll probably post here or make a thread trying to contact you after I get the h pipe or whatever I may get, thanks.
Zell1luk
Sep 29, 2015 10:36 AM
italiano67
Sep 22, 2015 08:42 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
cstrobel65
Sep 16, 2015 11:54 AM
WickedBowtie
Sep 11, 2015 11:24 PM
