header help!!!!!!!! dipstick and headerbolt question??????????????????
Old May 12, 2001 | 09:25 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Been tring to install my 1 3/4" slp headers for the last two days on my 87 Iroc. What a bitch. First of all, how do I get the oil dipstick out? I can pull it about 6inches up but cant get it out any further. Its really in my way in installing the passenger side header. Second question is, a couple of bots wont go all the way in the head. I can start them with my hand and after abou two turns then they get tight. I try wrench and I am able to turn but with ALOT more force then there should be. The old bolts came out fine and werent rusted or damage or anything. Should I force the bolts in? If not what can I do?? Any other tips on installng these ba$tards??
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
[This message has been edited by john5.7 87Iroc (edited May 12, 2001).]
Old May 12, 2001 | 09:37 PM
dtpmike's Avatar
I ddint even mess with the dip stick, I bent it toward the front of the car so now the handle is under the AC compressor. It works fine. I woudl try those bolts on other holes to see if its the bolts or the wholes.
Old May 12, 2001 | 09:51 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
its not the bolts they are new and Ihave tried them in different holes and work fine. Anything I can do to those problem holes?
Im not to worried about the dipstick its just in my way while Im working and it gets annoying. I did bend it once but I didnt like the looks of the crease in the tube.
1987 Iroc 350
K&N filters
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
Old May 13, 2001 | 09:28 AM
Z28DJP1987's Avatar
Buy a tap the same size as the bolts and hand tap the tight holes. Don't force the bolts,this should work. Good luck
Old May 13, 2001 | 10:36 AM
dtpmike's Avatar
yeah rust probably jsut built up, a tap should work, I was lucky and there are no creases in my dip stick tube, a perfect bend, the dip stick goes in and out fine.
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
