Any Suggestions???
Old May 3, 2001 | 04:58 AM
NOCANDO's Avatar
Any Suggestions???
I've just installed Edelbrock TES headers on my Camaro...The problem changing spark plugs. I 've been able to replace all 7 spark plugs except of #1. After tigtening #1, I cant seem to get the socket out because of the header...the only solution was to loosen the header to get the socket out...Any suggestions???
Old May 3, 2001 | 12:12 PM
mcconahay37's Avatar
Use a wrench.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
SLP 1 3/4" headers
Old May 15, 2001 | 09:40 PM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
I ground down a hex end spark plug socket about 1/4" (grind a little then check it) to make all of them easier to get to. A wrench might also work. use a 3/8 or 1/4" drive socket too.
Old May 19, 2001 | 06:17 AM
NOCANDO's Avatar
Thanks for the tip...
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
