Coated SLP 1 3/4" headers on Ebay
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I just found a set of 1 3/4" Jet Hot coated headers on Ebay. I have a 305, so I can't use the 1 3/4", so i thought I would post it for others to try and get.
Good luck!!
http://cgi.ebay.com/ebaymotors/ws/eB...400059931&rd=1
Good luck!!
Car: 87 IROC-Z28
Yes they are. Just wish they were 1 5/8".
Car: 1987 Z28 Convertible
Transmission: 5-speed
Don't rule the 1-3/4" SLP's just because you have a 305. I didn't. But then again, I've done a ton to my car and don't expect most to do as much....
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
1.75" headers will work FINE on a 305!!!
If you can get em cheap, do it. Then you will already have them if you ever decide to put more motor in your car.
Car: 87 IROC-Z28
I autocross with this car and really need the low end torque that the 1 5/8" headers will give me. At some point when the 305 dies, I'll go to a 350, but will still keep the T5 in it. I can't go very wild on the 350 with the T5, so I believe I would be better off going with 1 5/8" headers instead of the 1 3/4".
But I'll keep an eye on this auction anyway. I don' think they will go cheap. I'm betting $500 plus.
Edit:
Geez, just checked. They are at $430 now with 6 days left. I'd rather go with the hooker 2055's from jet Hot for $497.
Edit:
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
