CAT QUESTIONS
Old May 16, 2001 | 10:31 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
CAT QUESTIONS
I HAVE THE FLOW 80 WITH 2 1/2 EXHAUST PIPE AND CUSTOM TIPS. THE SOUND IS A LITTLE LOUDER THAN NORMAL STOCK STUFF BUT NOT EARTH SHATTERING. MY NEXT CHANGE IS THE CAT. MY QUESTION IS IF A CAT IS GUTTED WILL IT PASS EMMISIONS IN ILLINOIS OR DO I GET THE HIGH LOW CAT? WILL THE GUTTED CAT OR HIGH LOW CAT GIVE ME THE SOUND MY CAR DESERVES?
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Old May 19, 2001 | 01:29 PM
Sandy Mandel's Avatar
I don't know about Ill., but, in CT, it is probably no longer possible to pass the NOx test with a gutted cat. The levels of N0x emissions would be too high as this is one of the gases the cat catylizes (chemically burns up)....
Old May 21, 2001 | 05:46 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
Yah you can pass a smog test.I just built an engine put the old exaust back on and when I rev the car pieces of the cat fall out of the tail pipe and it still past the smog test easily.unless you have an old engine or problems with your fuel injection system you should pass.My CO-% was .36, HC-ppm was 24, and the NO-ppm was 229.check out my engine combo on my web site.link down below.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
chazman
Aug 28, 2018 03:25 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
