Hooker Cat-Back with following mods...
Old Jan 12, 2003 | 08:23 PM
CETATornado's Avatar
After spending a rather long while searching through old topics, it seems most likely that I'll get a Hooker cat-back as part of my full exhaust. The only problem I have with it is the loudness level, at least at idle.
How loud can I expect it to be with a good set of headers and a high-flow cat? I'm also planning that I'll eventually get a heads/cam package - how much louder will this make it?
Thanks for the replies.
Old Jan 12, 2003 | 08:36 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
with the stock cam, you will see a difference in dB over stock but it won't be earth shaking. what are the specs on the cam and heads? (lift, duration, valve size) without that info, i couldn't tell you how much louder it would be after a cam head change.
Old Jan 13, 2003 | 08:25 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Hey.
I put the cat back on my car and it didn't get much louder at idle. You can still talk over it without having to shout or anything.
David
Old Jan 14, 2003 | 09:48 AM
As I won't be getting the H/C package for a long while,
I haven't considered the exact specs yet, or even what company I'll get it from. I don't want something excessively loud such that it's impossible to hold a conversation at a normal volume in or outside the car, but what I've herad is that the Hookers are rather quiet at idle. What change in volume would an "average" package make ?
Old Jan 15, 2003 | 03:12 PM
mw66nova's Avatar
Engine: 7.0L
could you be any more vague? average to me is alot bigger than average is to you. when i think of a crazy motor i think of a 400 small block bored and stroked to 434 cubic inches with 14* heads and .700" of lift with well over 300 duration and 2" Primary tubes with 4-5" exhaust, but to somebody else it could be a .488"lift cam with midly moded stock casting heads with 1 5/8" primaries and 3" exhaust. point is, without these numbers, i can't help you. my father has a .488" lift cam with stock casting heads and 3" exhaust with a 750 4bbl on top, just a mild motor with 10.5:1 compression. his motor is loud compared to most street cars, however, one can still have a conversation without shouting.
Old Jan 15, 2003 | 04:37 PM
I realized how vague I was being, hence the , but in there's no better answer I can give.
Thanks for your help.
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
