question for tes owners
Old Jun 13, 2001 | 07:26 PM
chrisandkristin's Avatar
i am in the process of puting on my headers now i just need to know how to get the steering column connector off and then back on again any help would be great...
Old Jun 14, 2001 | 02:31 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I just finished my header install. I didn't remove my steering column. I just took the bolt out of the motor mount and tilted the motor and they went right on. The brake lines I haven't figured out yet since they are rubbing my headers.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorker Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
Old Jun 14, 2001 | 09:44 PM
Jza's Avatar
Jza
pull the shield out of the way and there's a bolt through a clamp around a splined shaft underneath. just loosen the bolt, then use a flathead screwdriver between the clamp and the steering box and twist to slide it off the shaft. the shaft telescopes and pivots so you can easily move it out of the way.
Old Jun 15, 2001 | 04:28 PM
Thanks Jza, but can you give the location of the steering box (towards windshield or front of car)
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
chazman
Aug 22, 2015 02:01 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
