Problem with T56 and Hooker Long Tubes for 1991 Z-28's car
Old Jan 22, 2003 | 04:05 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I'm trying to get some second opionions on what to do about this problem. Here are some photos that explain it. The collector is touching the bell housing which will not allow installation of the headers on to the head. What do you guys think? Roy at thirdgenresource said the only way is to either replace with shorty's or grind away. I thought the sme way about grinding but is it safe to grind on the collector or bellhousing?
Attached Thumbnails Problem with T56 and Hooker Long Tubes for 1991 Z-28's car-mvc-008f.jpg
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Attached Thumbnails Problem with T56 and Hooker Long Tubes for 1991 Z-28's car-mvc-009f.jpg
Old Jan 22, 2003 | 04:07 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Attached Thumbnails Problem with T56 and Hooker Long Tubes for 1991 Z-28's car-mvc-011f.jpg
Old Jan 22, 2003 | 05:36 PM
David 91RS/Z28's Avatar
Answer for pic #3: Relocate knock sensor to other side of block.
Answer for pics 1 & 2: Good luck!
Old Jan 22, 2003 | 09:04 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
what part # are those headers? as for help ,,,,,, can you heat it with a torch enough to bend them out slightly . dont know what it would do to the coating though.
mike
Old Jan 22, 2003 | 09:48 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
they are the 2210's
Old Jan 22, 2003 | 09:53 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
dang you are SCARING me! I have a set of thirdgen Hooker LT's in the basement next to the miniram, next to the AFR195 cylinder heads! Right next to THAT is a box full of T56 pedals....
Maybe we should have pre-fit before getting them Jet Hot coated. That way we could have cut & rewelded the collector in order to clear the bell housing. I suppose you could do that, then send out for a recoat.
http://www.ws6transam.org/fcar.html
Old Jan 22, 2003 | 10:05 PM
ronterry's Avatar
Car: '94 Corvette
It only looks like you need an 1/8 of an inch, if that. Brake out the grinder, and start taking some off the bell housing first.
Doesn't even look like it's to near a bolt hole, so you'll be fine.
Ron
Old Jan 23, 2003 | 11:03 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
ttt
Old Jan 24, 2003 | 09:24 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Agreed on moving the knock sensor. I don't see a problem with grinding on the bellhousing right there a little. That is just the outer area of where the slave mounts so it isn't really all that big of a deal if you clearance it a little...... There is plenty of AL there to support the slave after you clearance it.
I have a couple questions though.... what crossmember are you going to run? What are you doing for a Y-pipe?
Old Jan 25, 2003 | 04:16 AM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
i have spohn crossmemeber and torque arm, not sure of y pipe but he said it wont be a problem
Old Jan 25, 2003 | 10:03 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The design of the hooker LT's demand that you pass the exhaust pipe under the transmission crossmember. This is because the long tubes dump BETWEEN the front subframes. If you are using a spohn crossmember then you will have significantly less ground clearance than with a stock crossmember. "It won't be a problem" is a matter of opinion. The spohn crossmember hangs significantly lower than a stock crossmember.
Tim
Old Jan 25, 2003 | 09:26 PM
ws6transam's Avatar
Tim
This is true. I'm going to have the same kinds of problems, since I have an early design Spohn 700R4 crossmember & torque arm. I am thinking of either getting a different torque arm & crossmember design, or in having Steve fabricate a custom crossmember that accomodates clearance for Hooker Long Tube Y-pipes. It's got to be possible, somehow. I'm going to have to change over due to the T56 different mounting points, anyway. I wonder if Steve is thinking about this issue...
Old Jan 30, 2003 | 01:30 AM
Matt87GTA's Avatar
cough cough.....SteveshouldmakesomeCrossMemebersthatwillmakesomeroomforLongTubes.....cough.....
(for T56 users too )
Old Jan 30, 2003 | 07:31 AM
Momar's Avatar
lol
Old Jan 30, 2003 | 09:10 AM
ws6transam's Avatar
Since someone asked for these over on the CamaroZ28.com board, I thought I'd mention it here. I have a bunch of stick-on T56 shift pattern plates for your console. .016" aluminum plate in black textured powdercoat and laser etched shift pattern in white. I'm selling them for $12 including postage. Created 'em myself with a buddy of mine named Dave Zug about a year ago. We occasionally sell them on EBAY for $20.
Anybody want one?
See them here and ignore the retail price.
Old Jan 31, 2003 | 08:20 AM
TRAXION's Avatar
FWIW - I e-mailed Steve awhile back asking about making something to work with the longtubes. I don't have his response with me at work this morning but, in short, Steve said that he will NOT be doing this. He said that if he does anything then he will be making a y-pipe for the longtubes that works with his crossmembers (possibly taking a different routing?). Personally, I don't see how this is possible while keeping good ground clearance unless it's a high dollar y-pipe with oval tubing.
Tim
Old Jan 31, 2003 | 11:21 PM
Shagwell's Avatar
Car: projects.......
First, I agree with the "fixes" that have been stated, move the knock sensor, and grind the bell. - As for the clearance, I'm about switch in a 5-speed and Headman LT's. I plan on building a crossmember that loops upward on both sides of the tranny. I'm going to run the headman universal x-pipe, and put 2 Aerochambers w/ dumps where my rear seat lumps used-to be. Then I await some money saving for the Richmond 6-speed...
later, justin...
p.s. - TRAXION, how's that car of your's doing anyway...?That is one sweet ride...
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
