84 exhaust manifold, 87 manifold any difference?
Old May 18, 2001 | 10:33 PM
jersrjr's Avatar
Car: Looking for an f-body
I put 87 four barrel 305 in my 82 Camaro. Bought exhaust system from a 84 camaro came with manifolds, y-pipe, and rest of exhaust. My question is the y-pipe will not go up to the passenger manifold. It looks like the manifold is at the wrong angle. I was looking at the manifold that came with the exhaust and it appears to be angled differently than the manifold that is on the motor. Other than that the manifolds look identical. Is this possible? Also is there a heat riser or something that goes between the manifold and the y-pipe because I went to buy a donut gasket for it and autozone said it is not required, but by looking at it, it should have one. unless there is supposed to be a heat riser in there. The y-pipe is one of the big ones that has the four bolt catalytic converter that is ovaled. Is this one anygood? thanks
Old May 19, 2001 | 02:08 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
On the older carbed engines there is some odd little valve on the manifold on the passenger side(I forget what it's called right now). It has something to do with emissions and making the motor warm up faster. The 87 & newer didn't have the valve due to FI (so I've gathered). I can tell you the factory exhaust didn't use donut gaskets from the pipe to the manifolds (from the few I've redone). My 84 lg4 has the valve on the PS manifold as to where my 87 bird didn't. That might be your angle/space differece
-Welders get better penetration
Old Jun 16, 2001 | 06:54 PM
mikeage2's Avatar
JERMEY:you need to pay me for that exhaust before you bolt it on.GUYS,this guy took me for $80.he was supposed to leave me $120 and take the exhaust(i was out of town).when o got home i found $40 and a note saying that hed send the rest later by money order.its been more than a month and no word.his phone is now disconnected now too.get a hold of me man im sick of this game.
heres his info:
jeremey sanders
19w south street
divernon il
(217)=628-9002
jersrjr@msn.com
please email this guy and tell him to pay up!!!!!
mike
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
timonator
Aug 11, 2015 09:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
