The X-pipe
Old Jun 17, 2001 | 09:11 PM
Jinx2148's Avatar
The X-pipe
All the little 5.0 stangs I know have X-pipes(like an H but no tube connecting between the two main tubes, instead they cross each other and are connect that way hence X pipe), I don't know if any of you have heard of them but it supposedly equals the flow from each header. Do any Camaros have them?? Or is it just some piece of Ford crap that won't help performance?
Old Jun 17, 2001 | 09:36 PM
One Eyed Jack's Avatar
I think all it does is make the sound a bit smoother. I doubt any performance gains.
Old Jun 17, 2001 | 10:05 PM
steve8586iroc's Avatar
The Ford factory pipe is an H-pipe not an X-pipe. There is some advantage with the x-pipe over the h-pipe. The scavaging effect is greater and there is a better torque curve as well. As for a third gen camaro the stock exhuast is a single pipe from the cat back to the muffler so a x-pipe would be out of the question. If you intend to drag race only then you could use a custom dual exhaust if you wanted.
Steve
Old Jun 17, 2001 | 11:50 PM
Fastcamaro87's Avatar
i would think that it would flow better than an h-pipe, because instead of the exhaust having to make a 90 degree bend, the transition,is smoother..
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Jun 18, 2001 | 12:29 PM
88IROCs's Avatar
In the June 2001 issue of "Hot Rod they did a test on a 442 cid Olds small block. The test used a totally open exhaust, duals with muffler's, duals with muff and an 'H', duals with muff's and an 'X'. The best HP was benerated by the totally open exhaust. The plain duals and duals with 'H' suffered significant power loss. The duals with 'X' suffered a minor horsepower loss but gained torque, while significantly quieting the exhaust(vs the open exhaust and duals with no-crossover).
The results:
Open Exhaust -
430 hp @ 6850, 384 lbs/ft @ 5600
Duals w/no crossover -
412 hp @ 6650, 371 lbs/ft @ 5600
Duals w/H-pipe -
419 hp @ 6600, 378 lbs/ft @ 5600
Duals w/X-pipe -
428 hp @ 6600, 391 lbs/ft @ 5600
All of the tests were done on a chassis dyno.
[This message has been edited by 88IROCs (edited June 18, 2001).]
Old Jun 19, 2001 | 01:22 AM
Gta-Paladin's Avatar
88 i went and got that mag and everything and was reading down the posts then u had to go and post it
i love the way it looks when it's launching
Old Jun 22, 2001 | 12:33 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Hey, I might go with an H pipe .
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:234 dur at 050 488/488 lift,2500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.
Camaro_383
Sep 11, 2015 11:28 PM
formula_novice
Sep 5, 2015 03:58 AM
