AIR Questions
Old Jan 25, 2003 | 12:15 AM
jthorval's Avatar
Car: 1991 Z28
Engine: 5.0
AIR Questions
I plan on removing my AIR setup on my 91 Z. Does anyone have some pics of how to remove this junk, or else a step by step process laid out? I dont plan on putting in headers(yet)and I will be removing my cat, is there anything there I should be aware of? And do you have to burn a new chip to compensate for no AIR?
Jared
Old Jan 25, 2003 | 07:19 AM
llvll4l2c91350's Avatar
This is how I did it:
Disconnect the rubber hoses going to the tubes on the manifolds. Removed the check valves. Removed the AIR diverter valves. Removed the pump. Intalled a new different size belt (#968K6). I didn't remove the air tubes attached to the manifolds or the tube going to the CAT, but if you want you can go ahead and do this. I just left it alone cuz I will be installing headers soon so I might as well leave the tubes there. I also went to the hardware store and got caps to put on the tubes where the check valves were. I don't believe burning a chip is necessary. My engine seems to be running the same without one.
Old Jan 25, 2003 | 09:26 AM
jthorval's Avatar
Car: 1991 Z28
Engine: 5.0
So do I need to cap off the holes in the manifold if I take those tubes off?
Thanks, Jared
Old Jan 25, 2003 | 10:11 AM
Yep. A hardware store should have something for that.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
wruiz
Aug 13, 2015 09:07 PM
