just wondering for you guys running full length headers... do you have to take the pass. side off to change the starter?? i really hope the answer is no :lala:
the number 8 primary tube on the hooker long tubes come off and ive told that comes off so u can get to the starter.
You can't even use a stock starter. Mine fit, but it was right against the header tubes. I bought a Mini starter, it goes in and out w/o touching the headers.
how much was ur mini starter and where did u get it?
Summit Racing, around $230 for my CSI starter. A few people I know use a $125 mini starter from a place called Tommy Johnson Motorsports - none of them have called this starter junk. If you shop around you can find deals like that.
Quote:
Which long tubes to you have? And yes you can change the starter with the headers on. I have the hooker lt's and installed the starter with the headers on other than the removable #8 primary which I think is probably mostly to get to the wiring.Originally posted by 86 IROC
Ben
so Momar i wont have any problem with my hooker 2210 headers and stock starter?
B4Ctom1
close
heres one for ya http://www.hawaiiracing.com/special_starter1.html
Thats not exactly what I meant. I meant that you can change the starter with the headers installed. That said, I have the 2210s installed with the stock starter. I plan on going to a ministarter soon but have started the car fine with this combo. The one problem is on the big part of the starter that faces the front of the car there is a part that sticks out farther than the rest in the center. Mine is either increadibly close to touching or touching. I have not started driving the car yet so I dont know but this may cause problems with the starter not wanting to work to restart the car after it has been running a while and got the starter hot. Here is a pic of mine how it is now.
Quote:
Ben
They are identical to yours, Jet Hot coated & everything. My stock starter barely fit, I actually had a few people tell me that it wouldn't fit. Just for arguments sake, my starter was not a cheap auto parts store replacement, it was original GM.Originally posted by Momar
Ben
removable primary... nice... i wonder if those hedmans have it too.... ill have to keep that in mind... thanx
you wanna get rid of em? pm me...
withheadmans you have to drop teh starter, but i thinkt ath would be easy hell to do anyways, i had to problem by my self.
1989RS
close
- Join DateDec 2002
- Locationfort walton beach florida
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
- Enginenothing right now
- Transmissionj.w. performance th350 3500 10" stall... soon to be t56
- Liked:0 Times in 0 Posts
i have hedman long tubes and a full size el cheapo autzone high torque starter and it fits without taking the header off or touching the starter (without clearancing the header)its just a pain in the butt to change with the tranny cooler lines running by the oil pan
I actually work for them part-time on the weekends. lol
