help with header installation
Old Jul 4, 2001 | 05:59 PM
jseversole's Avatar
I'm installing a set of dynomax headers on a 91 rs. The driver's side header won't slide into place because of the steering column. The instructions do say to take it loose, but I can't figure out how. There are two bolts which I loosened, but it still didn't come loose. Can anybody help me out?
I've also had to remove the catalytic converter temporarily. What is a good replacement converter? Opinions vary on converters, but I may put a new one on for legality's sake.
Thanks.
'91 RS Camaro, Red/black interior, T-tops, 305 TBI/Automatic, open element air cleaner, Flowmaster 3" cat-back,
Hypertech thermomaster chip.
'01 Z28 convertible, White/Black leather/black top, six speed, hurst shifter, Eagle GSC tires.
[This message has been edited by jseversole (edited July 04, 2001).]
Old Jul 5, 2001 | 03:11 AM
Casey'91Z28's Avatar
I took the steering column out there are some bolts you take off or loosen(can't remember too well) and the column will come out. For the converter I got a Catco 3 in universal converter from summit for $99, so far so good.
'91 Z28 305, Auto trans, K&N filters, TPIS air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, SLP 1 5/8" headers, catco 3" cat, 14.7@ 93 mph(need new times after exhaust)
Old Jul 6, 2001 | 01:35 AM
iroc5speed's Avatar
catco is a good converter, and random tech makes a nice high flow too, but unless you've got a straight up race car you probably won't need it. the random techs are about $200.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
