Dual exhaust questions
Old Jan 31, 2003 | 12:30 PM
676983camaro's Avatar
This is on a 83 Z/28 with a 305 rebuilt with less then 10,000 miles, headers, 268ex cam, no computer, elederbrock carb and intake. Here in washington they will make you put cat on, but no emmison(sp) testing later. I would like to do this only once with the thought that later I would put a 350 or 327 in it.What size of pipe would you recommend and mufflers. Will I have a ground clearance probs? Single pipe split in the back or true dual. If you have any other input please speak up. Thanks as always
Old Jan 31, 2003 | 12:44 PM
Momar's Avatar
Single 3" with the duals at the back I think is supposed to support up to around 350 hp. I myself went with dual 2.5 inch though. There are some major things you have to take into consideration when trying to run true duals though. I would get under the car and look because there isnt a lot of room.
Ben
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
