What size headers for a mild 350?
Old Jul 12, 2001 | 06:18 PM
84TransAm's Avatar
Ok, I have a new Goodwrench 350 sitting out in my garage, and i'm debating what headers to use.
A few months ago I ordered the Edelbrock TES for a LG4 motor, so that's what I'm considering using (available, and already paid for). How well will they work on this 350? It's rated at about 239 hp with the log headers on.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Soon: Edlebrock Intake & TES
Old Jul 12, 2001 | 06:30 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
1 5/8 is all you'll need use what you got if you gotta buy em go with slp or as&m!!!!!!!!!
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
slp catback tomorrow(7/13)ed wright's fastchip saturday!!!!
Old Jul 14, 2001 | 12:14 AM
iroc5speed's Avatar
the edelbrocks should work fine for that engine. if you don't like them you can always ditch them later, but I'd say go for it.
Old Jul 14, 2001 | 11:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The primaries are fine, but the y-pipe only has 2-1/4" at the cat. You would have been better off getting the HO or the later TPI style with 3" at the cat.
I'd try returning them and getting the better y-pipe if I were you. Latest CHP article "My Generation Camaro" made the same mistake, they just fixed the y-pipe and made it 3" (and they only have a 305 so far). Unless you're an exhaust expert, exchange would likely be the better route.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
