What part is hitting on cars with SFC?
exactly what part of the exhaust is hitting on cars with subframe connectors? is it the cat or is it the actual Y Pipe?
FloridaRacer.com
FloridaRacer.com
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
My cat was hitting the rectangular cross brace of the kenny brown system, and the Y-pipe hit the front 12" of the RH SFC tube.
We ended up cutting the crossbrace and relocating it, as well as chopping off the front twelve inches of the subframe connector.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Daniel Burk
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its the y-pipe that hits. SFC designers are smart enough to build them not to hit the car. I had no troubles with my Alston's.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Kevin, do you have single or dual cat headers?
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
I havn't had any clearance problems with my Spohn SFC's, the install was a lil tricky on the welding, sfc to subframe angles were a lil off... but as far as clearance goes, they do not lower the stock exhaust, and they come with cross y-braces on both sides of the car. DEFINITE handling difference.
Brian P.
'91 TransAM: 305TPI -=flowed=-
Brian P.
<font face="Verdana, Arial" size="2">Originally posted by 98_1LE:
</font>
</font>
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have alstons and single cat with 3" exhaust and my exhaust isn't even close to hitting.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
** Added so far **
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
1992 Trans Am
Aug 8, 2015 08:16 PM
