Would This Work, to help pass Emissions???
Old Jul 21, 2001 | 09:02 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I am about to have new gears installed and at the same time I am getting new exhaust installe. My question is I have tried to pass emissoins 5 times, and I was wondering since I getting rid of my exhaust can I maybe create some kind of exhaust leak whether at the headers, the intermediate pipe, or the muffler to help reduce the amount of gases that exit my tailpipes.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 21, 2001 | 02:05 PM
Like a ROC 89's Avatar
Well you can but it most likely wont work. Just run your gas tank down to 1/4 and put like 8 bottles of dry gas in there.
Old Jul 21, 2001 | 02:30 PM
Car: 99 Formula
Axle/Gears: 342
I've tried that but with alcohol instead, didn't help.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Old Jul 21, 2001 | 03:36 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Mark put a standard 195 thermostate in your car and then see what happens. You may not have a computer controlled system but the hotter your engine runs "to a point" the more completely the gas is burnt. You also might want to get a cat put on your system, make it removalble ..IE 2 sets of headder collectors for quick R&R.
SSC
Old Jul 21, 2001 | 04:02 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Exhaust leak won't help you. They don't check the quantity of gas.
I hate to say this, but you probably need a cat. Modern cats aren't a significant flow restriction, and really help clean the air.
Bite the bullet and get a cat. You can likely pick one up for less than $100.
--andrew
Old Jul 21, 2001 | 04:30 PM
Car: 99 Formula
Axle/Gears: 342
It's not really a money issue, it's more of a performance and sound issue to me. I can pay $14 a month to take the test until I pass so it's not big deal, it's just an idle test. By the time my car gets tested the temperature is around 200*, so I don't think I need to change thermostats. I readjusted the A/F mixture screws on the carb and that seemed to help, so maybe I'll keep tryin. I just figured if enough gas could escpape before they reached the collector hoses they attach to the tailpipes that it would reduce the readings.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Spyder_TheGamer
Dec 25, 2015 05:07 PM
jbd1969
Aug 17, 2015 07:06 PM
sreZ28
Aug 14, 2015 07:48 PM
Street Lethal
Aug 12, 2015 11:33 AM
wruiz
Aug 11, 2015 02:59 PM
