So how hard is it to install SLP's
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have heard so often that it is to hard to install SLP headers. What all is involved. What makes them so hard. Would a custom car place have trouble. I was quoted $250 for headers (install price) from a high performance car place. If they are so hard to install I will have them do it. I know they are the best but what is the HP diff between TES and SLP and Hooker. Anyone know? Plus if you get any other header coated, it all evens up just about for a great set of headers.
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Hooker 3" Areochamber
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/28,000 Pampered miles
(Still have the original wiper blades)
1990 RS 305 TBI T-5
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Do a search on this and the Aftermarket parts board on SLP headers. There is enough there to keep you busy all day.
Poor workmanship seems to be the major problem.
Most of these Cars the guys on this board are building. Will never see an improvement worth the hassle/price to swap from one to the other.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Most of these Cars the guys on this board are building. Will never see an improvement worth the hassle/price to swap from one to the other. ------------------
I didn't have much trouble at all installing the SLPs. I had already done the motor mounts, so that probably helped. The only difficulties I encountered were getting the far rear bolt on the pass side to start and remembering how the brackets went together. I took off more than I had planned and didn't have any pictures or drawings of how they went together. I had to rebend the flexible brake line so it wouldn't sit on the header, but that is easily done by hand. I dropped the headers in from the top. I also had to get spark plugs with 90* boots so they would clear the header. This was on my 82 carbed motor with v-belts and NO smog equipment, so that helped. It took about 1 1/2 days.
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
82 Camaro:
350
Eibach Pro Kit
SLP 1 3/4" headers
ambainb
Apr 25, 2016 09:21 PM
