Which brand has both outlets? (On driver's side))
Old Feb 6, 2003 | 11:06 PM
BowtieFever's Avatar
I was just curious what aftermarket company has the dual outlets, to their muffler, exiting on the driver's side? I believe SLP does, with a 3" inlet. But, I wasn't sure if they were the only one's. Thanks!
Old Feb 6, 2003 | 11:29 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I think one of the Flowmaster kits for 3rdgens is like that.
Old Feb 7, 2003 | 02:46 PM
Brett Gutshall's Avatar
The flowmaster kit has a single 3" outlet on the drivers side, not dual. The slp system has dual 2 1/2 outlets on the drivers side, which i think look really good. I think dynomax has a system with dual outlets but its a piece of crap.
Old Feb 7, 2003 | 04:21 PM
J/W what brand you guys thought this one was? I was thinking it was the SLP one.
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6763
Thanks for the replies.
Old Feb 7, 2003 | 04:48 PM
Definitely looks like an slp.
Old Feb 7, 2003 | 07:19 PM
Z28DJP1987's Avatar
SLP two on the left side. The e-bay ones don't look like Stainless
Steel.
Attached Thumbnails Which brand has both outlets? (On driver's side))-iroc-exhaut-tips.jpg
Old Feb 7, 2003 | 08:58 PM
MikeS's Avatar
Even though the ones there on ebay look pretty nasty, the whole setup still looks like SLP to me. The shape of the muffler and the bends in the tailpipes look correct to me, although the inlet to the muffler doesn't look like a slip fit. Mine is a slip fit connection there. Maybe they aren't all the same, or i am just seeing the picture wrong.
Hey Z28DJP1987,
what do you use to keep your pipes looking so good? Mine are somewhere in between yours and the ebay ones (dull grey/brownish).
MikeS
Old Feb 7, 2003 | 10:07 PM
After looking at SLP's website...it does look like an SLP one to me. But, all the SLP's mufflers are stainless steel. So, maybe it is just corrosion or the setup is really old.
Anyway, how do the SLP muffler's sound. I was looking for something alittle deeper, throatier, and louder than my dynomax super turbo.
Old Feb 8, 2003 | 02:27 AM
Camarokid01's Avatar
Gale Banks makes a 2 on the left exhaust for our cars, sounds really good, that's what the one on ebay could be. Do a search on yahoo or something you can probably find their website there, I think they are a little pricey though.
Old Feb 8, 2003 | 02:38 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Dynomax has a superturbo with a 3" in and dual out driver side 2.5" outlets.
Old Feb 8, 2003 | 07:00 AM
85TPI400's Avatar
It seemed that who ever owned that car was into the SLP stuff as he is or was selling SLP runners and Headers off the same car. It seems like it be safe to assume it was an SLP. If it wasnt, all the above mentioned exhausts are extremely similar and you most likely couldnt tell the difference between them anyway.
Old Feb 8, 2003 | 07:27 AM
Z28DJP1987's Avatar
MikeS
Thanks those SLP pipes are over two years old. I did polish the pipes when new with a very fine sand paper to remove the as rolled finish and after just normal polish or wax.
For those interested the sound is very good at idle, and when you get on it. But very quite when at freeway speeds so not to get on your nerves. A happy user of SLP products.
Old Feb 8, 2003 | 10:13 PM
MikeS's Avatar
Thanks for the tip, I'll try hitting mine with some fine sandpaper and then try some polish. So far, polish alone hasn't done anything.
As for the sound, I like it. Not too familiar with the super turbo, but would expect any turbo style muffler to sound similar. The SLP is pretty much right where I want it in terms of volume. It is loud enough that it sounds good, but not so much that it ever bothers me. I guess I could go with the "set's off car alarms" (occasionally) that people seem to say. I'd recommend it, especially since it's one of the less often seen looks.
Old Feb 13, 2003 | 07:57 AM
extreme3rdgens's Avatar
Flowmaster makes both a 40 series and 80 series with 3 inch inlet and dual 2 1/2 inch outlets on the same side. I have installed a few of these mufflers. This is one I installed a few months back for a customer. The 80 series is quiet the 40 series sounds bad ***. It actually sounds a lot louder then the american thunder system. Had two T/A's with same engine combo's and each system at the same time, the 40 series same side outlet screamed.
Extreme
Attached Thumbnails Which brand has both outlets? (On driver's side))-86-red-ta-exh.jpg
Old Feb 13, 2003 | 09:40 AM
87 B4Z's Avatar
you can hear it real good towards the end when i go WOT, this is a shot from inside the car with the t-tops off.
http://luna.snu.edu/~operativex/nick/P2090001.MOV
Bert87
Aug 23, 2015 03:50 PM
Cameeeero
Aug 20, 2015 03:06 AM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
