For those who installed their own headers
Car: 91 Firebird
Engine: 6.0
Did your new headers come with adapters or new brackets for the power steering, A/C, and alternator? If not(because mine didn't) what did you use or do to overcome this. I have a set of Hedman headers with the AIR injection tubes. I bought some header bolts from Advanced Auto. I also bought some collector bolts for the Y-pipe. I am just worried about the brackets for the accessories. I have been really putting this off, but would like to do it before summer is up so I can enjoy the benefit of it. Thanxs!
-Jason
"Get this, no man with a good car needs to be justified."
91 Z28 305 TPI/ 5 spd
92 Formula WS6 305 TPI/ 5 spd
-Jason
i am a topic answering **** tonite
you should not have to reloacte any accessories. i put edlebrocks in my car and had no problems with alternator or anything else. i am not sure about the heddmans but i dont think anything has to be moved. the only problems are trying to fa-naggle them in but once they are in there is planty of room, and trying to put the collector bolt in on the pass side (frame rail soo close) at least on my car with my headers. but....i dont think yours should be too hard to put in. also you may get them in easier from the bottom. but i always did mine from the top
stock Y pipe though???? mine came with bolts and a new Y pipe
Transmission: 4L80E/4L80E
My Hooker 2055's (which I have yet to install) came with all hardware, including bolts and gaskets, and spacers with longer bolts for accessory mounts that used to go to the manifold.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 91 Firebird
Engine: 6.0
Darn it! I broke my cardinal rule! Never post about something without searching for it first!
Thanxs M-T. I really screwed up. I normally read questions and wonder why they didn't search for the answer prior to asking. I'll try not to make that mistake again!
-Jason
91 Z28 305 TPI/5 Spd
92 Formula 305 TPI/5 Spd
-Jason
My Edlebrock TES headers went in without any extra parts and without any bending of the brackets.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 88 IROC-Z (Sold)
Engine: 5.7L
My TES's went in pretty easily without bending anything other than a slight bend in the oil dipstick. I didn't relocate anything and I only had one accessorie bracket to mess with and a spacer and longer bolt (provided) solved the issue. The drivers side went in very easily with the valve cover off. The passenger side required the removal of the starter and the knock sensor, then it slid in nicely from below. The header to y-pipe bolts will be in tight locations so make sure you have extensions.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
my edelbrock headers came with a 1-2" spacer for the ac/ps brackets for the long front bolt on the stock manifold(drivers side)
84 Z28
78,000 miles
1970 350 ci 4 bolt chevy motor punched .030 over to a 355
stock 1970 heads with 1.94's and very mild porting
edelbrock rpm cam,intake, 750 4barrel
weisco 9.6/1 pistons & rings
edelbrock headers and catback (without the cat)
700r4 trans
3.23 rear (no posi yet)
[This message has been edited by Hanks1 (edited July 24, 2001).]
84 Z28
78,000 miles
700r4 trans
