Need Help, Should I remove my converter or not??
Old Jul 26, 2001 | 10:00 PM
Jas89TTA's Avatar
I got a 87 Trans Am 350 TPI and my cat is ratteling bad and I either need to replace it with a high flow one or just remove it and put a pipe in it's place. I'm in Florida so there's no emmision checks here, but I've heard that if I remove the cat I'll lose power with the TPI, Is this true? Does it need the back pressure? What was anyones experince by removing the cat on a TPI engine? What was it with a high flow cat?I've already removed all the emissions crap off my car. Any suggestions would help. Thanks, Jason
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.6 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, 24# SVO Injectors, SLP Cold Air Intake, Holley AFPR, LS1 Aluminum Driveshaft, Flowmaster Exhaust, Taylor Wires, MSD Coil,
Engine pic at http://albums.photopoint.com/j/Album...410&a=13413975
1992 Trans Am
May 10, 2023 07:19 PM
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
