Exhaust help?
Car: 1991 camaro RS
Engine: 305 Carb
Exhaust help?
hey, ive got a 91 rs with 3 inch flowmaster cat back system. i dont know whether or not i should go ahead and finish it off with a set of hedders and a y pipe or not. will it make that much of a difference? what kind of gains should i expect, and what would be a good kind to buy?
Thanks.
Thanks.
Transmission: 4L80E/4L80E
How much difference did you see with the cat-back?
Headers, y-pipe, & cat will help. You'll be as limited by your heads and cam as you are now with the stock manifolds/y-pipe/cat. But, without the headers/y-pipe/cat, upgraded heads and cam would be severely limited.
david068513
Sep 18, 2015 10:36 AM
