How Do I check for a clogged muffler??
Old Aug 1, 2001 | 06:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Not that it matters too much, because I am getting new exhaust installed in a couple of weeks, but I was wondering if there is any way to check with the muffler on the car. Would the muffler run hotter than normal?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 2, 2001 | 01:28 PM
Car: 99 Formula
Axle/Gears: 342
anyone?, I have access to a heat sensor tool where you point it at an object and it gives you a surface temp reading.
Infested
May 22, 2018 11:56 PM
formula_novice
Sep 5, 2015 03:58 AM
Justin92GTA
Aug 27, 2015 11:16 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
