which is better, pics inside!!!
Old Aug 9, 2001 | 01:42 AM
breathment's Avatar
which is better, i heard that the second isn't as good cause the exhaust has to turn around 180* to exit. while the first just has to split and goes pretty straight. i have the first on my car and am thinking about upgrading, but im wondering if it flows better then the second, cause if it does then i'll just get a new muffler like mine but better flowing.
#1 exhaust enters right side, leaves through dual left pipes
#2 exhaust enters right side, and leaves through pipes and left and right.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
[This message has been edited by breathment (edited August 08, 2001).]
Old Aug 9, 2001 | 03:29 AM
DualCarb's Avatar
I prefer #2, but #1 might give a better sound.
Old Aug 9, 2001 | 09:21 AM
RW91B4C's Avatar
Yes the first one does flow better and is a better design, just as you said. When looking for a new muffler look at the flow figs.-CFM
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
mud runner
Nov 2, 2015 07:30 PM
64Chief
Sep 12, 2015 08:05 AM
gt4373
Sep 9, 2015 10:29 AM
