mufflex 4 in question
Old Aug 14, 2001 | 11:56 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i was looking at the pics on someone elses post that had a 4in mufflex y pipe. that thing is huge. does that run all the way back under the driveshaft tunnel, am i looking at the right? my next question was could it be possible to run 2.5 dual exhaust back along the driveshaft tunnel, but then i rmembered the tourqe arm? is that mufflex pipe going to get in the way of the tourqe arm? just wondering, thanks guys. lil jay
Wide Open Till You See God...Then Brake
Old Aug 15, 2001 | 01:46 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I went with Mufflex since they were designed to work with Hooker SC/LT headers and since my 383 revs to 6,500. Thats alot of gas to expend. A 4" outlet pipe will certainly help me out.
Look at:
http://www.mufflex-performance.com//...ducts\new.html
Talk to these guys if you have questions....
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
