Exhaust manifold flow/bolt up question
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
I have my old stock exhaust manifolds from my L98 IROC-Z after I recently installed headers.
Some guy from the net wants to buy them from me to put on his LG4. Will they bolt up the the stock LG4 and stock LG4 exhaust system?
He would also like to know if they will flow any better than his LG4 manifolds.
Thanks.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, throttle body coolant bypass, Spohn SFC's on order, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Thanks.
2.8 MPFI, no mods
I don't know about bolting up but I do know they will flow better. Hope that helps half your question ...... I am guessing they will bolt up, but the Y pipe and cat would have to be changed as I believe those are two different types, but im not sure.
1989 Trans Am GTA, 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, 5.0L TBI, T-5, T-Tops, L69 Dual Snorkel, K&N - Sold
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
They will bolt up okay to the heads but the collector flanges are different between the two models. He would need an L98 y-pipe and cat setup at a minimum or a good exhaust shop could mate the pipes to the manifolds.
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Phil87IROC
transaero
Aug 31, 2015 01:14 AM
