best headers????
Old Feb 17, 2003 | 10:06 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
best headers????
Im in the market for new headers. Now I have triied the SEARCH key and it turned up one result about a t-shirt.
What is the best set of headers I can get for my 350? I want them to be jet hot coated inside and out with 1 3/4" primarys, I believe thats the size your supposed to use on a small block 350.
also I dont need any air provisions.
Prices and location could help out to, thanx.
Old Feb 17, 2003 | 10:14 PM
fastcamaro350's Avatar
This question would be best asked on the Exhaust board...
Old Feb 17, 2003 | 10:16 PM
IROC_5796's Avatar
I just figured that this board would be good because of all the traffic on it, everybody seems to respond more here, also I would like to see pics of headers people have on there cars...
Old Feb 17, 2003 | 10:49 PM
IROC_5796's Avatar
ttt anyone have any ideas on good headers??? I know most of you guys have them.
Old Feb 17, 2003 | 11:26 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Check the exhaust boards, this gets asked all the time.
Basically it varies depending on your engine, mods, and price range.
Old Feb 18, 2003 | 12:43 AM
MdFormula350's Avatar
when you search you need to make sure you search all open forums.
sounds like you just searched in the t-shirt board..
Old Feb 18, 2003 | 09:31 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
I like my edelbrocks.
Old Feb 18, 2003 | 11:10 AM
johnyIROC's Avatar
Hedman shorties are the best hedder for your dollar....
If money is not an object, look towards SLP and hooker long tubes.
Old Feb 18, 2003 | 12:31 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: best headers????
Hedman Ellites are one of the best deals for our cars, no smog provisions, ceramic coated, huge flanges and thick gauge tubing for 259.99. They are 1 5/8" tho, however 1 5/8" is by no means too small for your average or modified 350.
Old Feb 18, 2003 | 12:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Inadequate information.
There are all sorts of 350's out there. Tell us a little more about yours.
Factory? Or, modified?
Induction type?
Intended use? (street, daily-driver, strip-only, weekend warrior driven to track, etc.)
Emissions or ground clearance concerns?
SLP is the only outfit that recommends 1-3/4" primaries for a 350. They are shooting at the TPI/EFI with performance mods crowd using shorty headers. If you don't fit that mold, don't take their recommendation for gospel.
Old Feb 18, 2003 | 09:26 PM
Induction type?
I am an avid 1 5/8" header fan. I have friends running 11's on 1 5/8" primary headers. Too many people think they need 1 3/4" headers to go fast.
Old Feb 19, 2003 | 12:45 AM
IROC_5796's Avatar
Induction type?
my 350 is modified, bored .30 over heads ae done with larger valves induction is TPI w/nos, im not planning and racing at the track im more of a street racer, I just wanna have a little fun with the import crowd. Im located in canada so no need to worry about emmisions I have a standard so longtubes are out of the question. I would like a header that doesnt use the tipical 3 bolt collector, I want the fatory style, my collector from my old headers always hit the frame and fuel lines, I wont have a problem with the fuel lines now that Im going away from carburation.
Old Feb 19, 2003 | 08:57 AM
five7kid's Avatar
Any of the shorties out there will give you the ground clearance you have missed. The best bet is to get headers and y-pipe together - they have to be from the same manufacturer, since they all connect different.
If you go with SLP, stick with their recommendation and get 1-3/4" primaries. They sell them with or without the A.I.R. tubes, sounds like you can go without. The Hooker Super Comp shorties are nice pieces, 1-5/8" primaries, but have the A.I.R. tubes - you could cut them off and braze the holes shut if you wanted. The Hooker y-pipe is an excellent piece. Edelbrock TES are 1-5/8" primaries come with A.I.R. (same story as Hookers), y-pipe. Hedmans w/o A.I.R. don't have the O2 sensor fitting, you'd have to add that, and their y-pipe doesn't win any awards.
I wouldn't call your application "highly modified", so 1-5/8" primaries will be fine (unless you go SLP). Since you're going TPI, you need the O2 sensor fitting.
I also do not advocate street racing (even though you didn't ask). Very dangerous, uncontrolled, gives us all a bad name. Street performance? Fine. Street racing? One word - Don't.
Old Feb 19, 2003 | 10:01 AM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
For a stock or mildly modded 350, 1 5/8" primaries will work great. I have a friend who insists that his 1 3/4" headers on his stock LG4 make more power than the 1 5/8" ones would, but it probably makes less power and less torque. The edelbrock pieces are nice, I know two people that run them and they are very satisfied. They don't come ceramic coated though. hope this helps.
Old Feb 19, 2003 | 01:59 PM
llvll4l2c91350's Avatar
I have Edelbrocks on mine. Not too bad to install and will give a very noticeable low end improvement.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
