Please help, header problems!
Old Aug 17, 2001 | 09:03 AM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
OK I have two stupid problems. I got 1 manifold off and i am having trouble with the second one. I know there is a metal piece i have to bend away but i cant get at it and i need to know if anyone knows an easy way. My second problem is i cant get the header in on the drivers side. I bought headman headers for 82-92 camaro and firebird and i have a 91 z28 and i want to know what i should take off to get these headers in. Thanks
Old Aug 17, 2001 | 11:01 AM
Saywhut's Avatar
I just installed Heddmans on my 88 IROC.... Use a screwdriver to bend the locking tab out of the way, and you'll probably have to remove the D/S motor mount thru-bolt and jack the engine up on that side to get the header in........
Old Aug 17, 2001 | 11:13 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I ended up having to jack both sides of my motor up to get each header in. Just takes a few minutes to work the bolt out and put a block of wood on the jack. Be patient and it'll all work out well
Old Aug 17, 2001 | 12:14 PM
tacoboy's Avatar
jacking the engine is not necessary...if you work with that header for a little bit you will be able to get it in...i think i started mine by getting it as far forward towards the front as i could, then working it from there...it can be done...took me about 5 mins of finagling
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
