SLP Header install Questions.......
Old Aug 16, 2001 | 09:47 AM
skheckert610's Avatar
I've got an 84 Z-28 w/ stk exhaust. I'm probably going to go with SLP headers and a Random High flow cat and SLP cat back. I've heard form an couple different articles and posts here that the driver side can be a bear so much that the steering column had to be moved. Can anybody confirm this? Has everybody had these problems? Was the steering column just moved out of the way temp. or is it a permanent relocation? If so how is this accomplished??
Thank you
Old Aug 16, 2001 | 10:10 AM
87tpi420's Avatar
i just got a set of 1 3/4 stainless headers.
drivers side went in no problem from underneath. pass side went in from the top.
i have nothing in the car for emissions stuff or stock accessories/brackets, but had no problems getting them in. on the other hane with my brodix angle plug heads i found they will not fit, i even put a couple small dings in 3 or the pipe to no avail! wanna buy a new set with a few clearancing dents in them? i am going with super comps now........errrrrrhhhhhh this is irratating!
http://people.ne.mediaone.net/gdm/
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Aug 19, 2001 | 05:01 PM
Anbody Else got any comments??? What size is the SLP Y pipes?? What about an SLP catback system?? Anybody got any thoughts on that??
Old Aug 19, 2001 | 06:25 PM
BlackZee's Avatar
I have factory exhaust manifolds and SLP everything else. It sounds great, is reliable, and has good flow. All tubing is 3" in diameter. I have SLP 1 5/8" headers I was going to install, but they use a different y-pipe than the one for stock exhaust manifolds, so I am going to sell them. If you don't have the cash to get the whole system, start with the cat-back package first, most bang for the buck!
Old Aug 20, 2001 | 09:14 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I put in slp 1 3/4'S about 2 months ago. I did have to move the steering shaft thing out of the way which is very easy theres one or two bolts you undo and then slide it out of the way. After that it took like 5 mminutes to drop the header in
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or (still working on) http://members.cardomain.com/john87iroc
Old Aug 20, 2001 | 05:26 PM
But You just hook the steering shaft back up right????? I mean you don't move it permanently... I can't see SLP making a product that you have to move it for good.....
Old Aug 21, 2001 | 11:19 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
Right. just unbolt it, slide it ou,t and drop the headers in and put the shaft back and your done with that. Some people have moved their whole steering column over a bit or something like that but I didnt need to.
1987 Iroc 350
K&N filters
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
Old Aug 21, 2001 | 07:14 PM
82resto's Avatar
Hah... well, i used a dremel to grind my steering shaft down,and it still rubs a tiny bit when i take hard corners...
It depends on what kind of SLP headers you buy....i heard the 3 into one type (or something) don't rub.
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
theurge
Aug 21, 2015 12:46 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
drathaar907
Aug 6, 2015 04:20 PM
