Installed new super comps.. starter won't fit
Old Aug 22, 2001 | 10:46 PM
FasNuf91's Avatar
anyone have problems with this... i have long tube 1 3/4 hooker headers.... i tryed loosing up the header but it still won't go.... any ideas with out spending choo choo bucks on a mini starter
Old Aug 22, 2001 | 11:20 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
The directions that came with my Hooker LT (#2210) said you had to remove the tube for cylinder #8 and put the passenger header up near the heads, but not attached, then install the starter with the header up toward the radiator out of the way. Then bring the header back into place and install the tube for cylinder #8 and bolt the header to the head.
This worked for me! I even had the starter wrapped in a heat shield or blanket. It was a little tough to put the wires to the starter, especially with the cover in heat sleeving.
Good luck!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
slade5612
Aug 11, 2015 07:19 PM
milk
Aug 10, 2015 06:26 PM
