Y pipe cracked. New Y pipe or TES?
Old Aug 29, 2001 | 07:37 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I have a crack right where the 3 pipes meet. If I can't get it welded, is it worth the cash to go TES (will I really notice a differnce on my bird w/ the mods I have?) or just go for a new y pipe. How cheap can I get a new y pipe? Are there any other cheap alternatives for cat-forward systems?
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, 1000-CFM Demon Carb, Phase VI Chevy Bowtie Heads 2.05/1.60, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto Daily Driver: minor motor mods, more suspension stuff. MODS
one with a good car needs to be justified." JBMHR - Ministry
Old Aug 30, 2001 | 06:51 AM
BlackZee's Avatar
If you can't afford SLP headers w/ y-pipe now, I would recommend replacing your stock y-pipe with the SLP version. It is well made, 3" in diameter, stainless steel, factory-like install, and cost $169.
Old Aug 30, 2001 | 01:53 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
That sound reasonable. My bird is no racecar, just my daily driver, so I can't really justify putting 400 headers on it. It is just not worth the hp/$ ratio. Atleast then I would have a 3" y stainless Y pipe. Are you sure that they will work with stock manifolds?
Old Aug 30, 2001 | 01:56 PM
BlackZee's Avatar
I've had mine for 7 or 8 years, works perfect and is way better than a stock replacement!
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
LT1Formula
Oct 8, 2015 08:34 PM
