i have a 88 GTA with 5.7L and single cat. i like the sound if true dual exhaust. how hard would it be to convert to true duals?
- David
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
- David
It's not that hard. I say go for it! I like the performance aspect of it but also the sound of it is real good. I just added a crossover pipe today to my true duals and it sounds even better!
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
383 86 Camaro Z28
would i just have to get two cats, and run like 2.25 or 2.5 pipes all the way back with a cross over and two 50 or 40 series flowmasters or something like that?
- David
- David
