Power Loss???
Old Feb 26, 2003 | 05:20 PM
89RallySport's Avatar
Power Loss???
ok, I just recently had my new exhaust put on, hooker cat-back with a straight pipe and new y pipe (if it matters) and I knoticed a slight loss in power, well maybe slightly large. There was a AIR or some emmissions pipe going into the side of the cat before it was deleted, will that in anyway effect my loss of power, i'm sorry I dont know much about exhaust systems. Thanks!
Old Feb 26, 2003 | 10:23 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
I don't think deleting your cat/AIR caused your power loss, this is done all the time without trouble. One thing that comes to mind though is that sometimes after installing a freer flowing exhaust, your fuel mixture goes lean because of the extra flow. Assuming you have fuel injection, I'd say you might need to increase your fuel pressure to compensate.
Hope this helps.
Old Feb 27, 2003 | 09:13 AM
nope, its the dreadfull 305 tbi, is the fuel ajustable in this style fuel injection also?
Old Feb 27, 2003 | 11:11 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
not sure about TBI but you have to get a AFPR to adjust on TPI i believe
Old Feb 27, 2003 | 12:00 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
The tpi apfr wont work on the tbi. In the how to section of this board it will tell u how to turn your existing one into an adjustable one.
Give it a few days for your computer to learn though.
Old Feb 27, 2003 | 01:53 PM
thanks for the idea, yah its been like this for a few weeks now though, I'm not sure what went wrong. I had alot of stuff needing replaced and I could not get upto speed at all cause my tranny mount was gone and the shifer would come up and slam into the car so I drove real easy til it all got fixed, with fresh mounts,exhaust, suspension it feels like a V6, cant even chirp 2nd gear when before I could hit 3rd easy. I dont understand it at all
Old Feb 27, 2003 | 01:55 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I am not sure why you lost power, unless one of you plugs where mabey damaged during installation. A free flowing exaust like that should not create a power loss, you should get a least a minimal power gain if anything.
Old Feb 27, 2003 | 04:00 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
i think i might no
how does the car idle and start now that you did the up grade.
one time a while back me and my friend thought that we would take the stock muffler off his toyota pick up truck and put one of the realy long i think 17 inch cheap thrush mufflers on it and after we got it installed the truck ran liek total srap and would idle for car eather and teh truck was feul injected also but as soon as we put the normal muffler back on it ran like a champ again.
i was under the asumpyion that it didnt have enough back pressure maybe u are seeing something simular in your car.
Old Feb 27, 2003 | 10:19 PM
yah it does have a little problem at idle but nothing big. once in a great while it will stall but not usualy. I just remembered I had just installed a new fuel pump, is there a calibration or something for that? Or maybe dirty fuel injectors??
Old Feb 27, 2003 | 10:24 PM
LastViceRS's Avatar
Car: '91 RS
Have you replaced your fuel filter lately? A semi-plugged filter could cause a pressure drop that would cost you power.
Old Feb 28, 2003 | 12:07 PM
Yah that might be a good idea, any recomendations on prices and what type's a good one?
Old Feb 28, 2003 | 11:18 PM
LastViceRS's Avatar
Car: '91 RS
A fuel filter shouldn't cost you that much. I don't remember how much off the top of my head - $10? I usually use Fram, AC Delco, or NAPA filters.
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
