Hooker Header Help ASAP!!!!
Old Sep 8, 2001 | 01:46 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Hey I got a set of hooker header shorty headers, well I got them in and now I can't get my plugs in!! I can't even get the spark plug socket on some of the plugs!! What did you guys do, or what type of plugs did you use?
Old Sep 8, 2001 | 01:50 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
You need shorty plugs from Accel or even some Bosch plugs are a bit shorter. Autozone has them.
I had to make a short 5/8" plug socket to work with some of my plugs. Also, you can use the boxed side of your 5/8" wrench on the plugs too. Plugs don't need to be extremely tight, just snug.
Worse case will be to loosen headers and install plugs.
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old Sep 11, 2001 | 01:05 AM
blitz92rs's Avatar
im having the same problem with the spark plugs im not sure what kind of headers i have on, they were on when i bought it but hooker header sound familiar. Anyway you said you could loosen the headers up have you tried that? my friend said it probably wouldn't work but he don't have a car so id trust you guys more then him,so i called an autoshop to put the plugs in the they said it was going to be about 300-400 and i dont have that kind of money so you think they would pull back far enough to get them in?
Old Sep 11, 2001 | 05:15 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
If most or ALL your spark plugs are blocked from being installed, I'd rethink the use of those headers. If one or two are blocked, then you can probably simply loosen your headers enough to get the plugs installed. You can dimple the headers too or get shorty Accell plugs as well. If you do this use a plug that will last a while.
I have one plug where I had to make my own super shorty plug for my AFR heads and Hooker SC/LT headers. I'll do that for one plug, but not all 8.
Hope this helps a bit.....
Phil87IROC
[This message has been edited by Phil87IROC (edited September 11, 2001).]
redformula88
Oct 14, 2015 06:08 PM
Chevykid810
Sep 28, 2015 12:57 PM
92projectcamaro
Sep 24, 2015 08:09 AM
ssgt usaf
Sep 21, 2015 12:45 PM
hdis2002
Sep 8, 2015 02:52 PM
