Answering if 3rd gen can have duals
Old Sep 16, 2001 | 01:16 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
HELL YES. I was at bowling green last night and there was a red formula that had hooker super comps and 3in duals with an h-pipe. ohh it sounded good, better than any single exhaust will ever sound. there was plenty of ground clearance even with the 3inch pipes. i am gonna have 2.5 just cause 3 is so freakin loud. i have wanted to see a car with this set up and just so happens i was walking buy and saw two flows hanging under the rear passenger seat. sweet setup and sounded awesome.
Wide Open Till You See God...Then Brake
Old Sep 16, 2001 | 01:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Several people on this board have true dual exhaust. By the way you said you're going with 2.5 duals. What is your current engine setup right now, if it's stock you might be going overkill. There was a post a few posts back that I believe said dual 2.5 should be for around 300hp engines. Just something to think about.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 16, 2001 | 03:09 PM
LilJayV10's Avatar
Engine: 406 Roller
the engine thats going in the car is a 357(.040 over) with 461 double hump heads, 2.02/1.60 ported polished, 268xtreme cam, long tubes, stealth intake, TH350 w/stall and shift kit, 3.42 rear gear.
Old Sep 20, 2001 | 01:05 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
When you install your true dual exhaust also add a crossover pipe .
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Warlocksirix
Sep 3, 2015 12:26 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
