HOOKER SUPERCOMPS FOR L98 ANGLE PLUG HEADS?
Old Sep 18, 2001 | 07:30 AM
PROCHARGED89Z's Avatar
Hooker sells supercomps for angle plug heads will they fit L98 angle plug heads?And would regular supercomps that fit straight plug heads fit l98 angle plug headsThanks
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Sep 18, 2001 | 09:15 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I am trying to figure out the same thing. Check out these posts......
https://www.thirdgen.org/messgboard/...ML/001642.html
https://www.thirdgen.org/messgboard/...ML/000775.html
https://www.thirdgen.org/messgboard/...ML/001831.html
No matter what - I should know shortly. I already have the hooker super comp long tubes and I will be installing them in about a month or so. I have AFR190 L98 angle plug heads.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Sep 18, 2001 | 03:51 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Pro/Trax,
What are you guys gonna do for the exhaust pipes from the headers back, any ideas??
Here's what I did...............
http://www.geocities.com/cfrios/Phil...l?996948051310
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old Sep 18, 2001 | 05:26 PM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
Is that the Mufflex y-pipe? I wonder if the y-pipe from Internet Racer's Supply will fit the long tubes. It says its for 93-97 F-body's but it might. btw, its $170 for the y-pipe instead of $250 for the mufflex piece.
87 IROC-Z
Minirammed Solid Roller 377
Old Sep 22, 2001 | 04:13 PM
ttt
Old Nov 8, 2002 | 05:23 PM
TRAXION's Avatar
https://www.thirdgen.org/techbb2/sho...?postid=976892
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
