any tips on removing my muffler?
Old Mar 10, 2003 | 04:45 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i am replacing my stock muffler with a new flowmaster muffler i should be getting in a few days so i figured id start now and remove my old muffler, much easier said than done! i just tried for 3 hours to get it off and i couldnt even get it to budge, its not welded on its just clamped. i tried a hammer with a screwdriver, just a hammer, i tried shaking it and trying to get it broke loose but i just cant do it, anybody have any tips? how did u get yours off? thanks
Old Mar 10, 2003 | 07:16 PM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
First you realize that the stock muffler is longer than the Flowmaster and once installed you're tailpipes will not exit the car in the same location meaning they probably will not be lined up
in the same location they once were but since they are the stock
pipes you can't really see them from behind the car anyway unless you later add chrome tips.As for getting the muffler off,try
takeing a small angel grinder and slice the pipe a couple of inches longwise where it comes out of the muffler and then try getting a screw driver in there and spred the pipe apart and slide the muffler off.BE CAREFULL YOU DON'T GRIND THRU BOTH PIPES!
Old Mar 10, 2003 | 07:25 PM
bad_ta_05's Avatar
Car: 85 trans am
i didnt know that, thanks for the info bill. i will probably end up trimming off some of the tail pipe to make them as even as i can. i do have chrome tips on my tailpipes but they are the screw on type so i can take them off if needed, i was going to weld them on but i want to wait till i get the muffler on adn stuff, does anybody know about how much shorter the flowmaster is than stock? thanks
Old Mar 10, 2003 | 07:37 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
i sawed mine off with a sawzall....took all of about 30 sec to do...helpful hint: put 2 jack stands under the muffler it will hurt when it falls on u
Old Mar 10, 2003 | 07:40 PM
bad_ta_05's Avatar
Car: 85 trans am
when you use a sawzaw does it damage the i pipe at all? i think a grinder will work pretty good ill just have to be careful and take my time.
Old Mar 10, 2003 | 07:43 PM
Transmission: autos
no, id say cut more towards the muffler cause u might need extra pipe left on..i took my muffler off and put a new one on with no troubles..except the muffler fallin on me of course
Old Mar 10, 2003 | 08:47 PM
What I ment by you're tailpipes not exiting in the stock locations is
that like before where you're tailpipes were set in about 10 inches
from the sides of the car, they now will be offset and one maybe in 10 inches and the other over a foot in from the side of the car.
Old Mar 11, 2003 | 07:34 PM
80 Camaro 355's Avatar
Car: 1980 Camaro Berlinetta
Engine: soon to be 383
Transmission: TH-350
Axle/Gears: GM 10 bolt 8.5 3.23
Two words....Saw Zaw......:rockon:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
