How will getting rid of my EGR system effect my engine?
Old Mar 13, 2003 | 07:44 PM
72Blazerod's Avatar
I am putting a 1990 Vette L-98 into my 1972 Blazer. The stock exhaust manifolds totally block the boss on the block that would allow me to run mine stock clutch linkage. I was thinking about getting headers to solve this problem but that would mean losing the EGR. How would this effect the running and performance of my engine? Any suggestions on reasonable priced decent headers?
Rod
Old Mar 13, 2003 | 10:31 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
If your keeping all the TPI, computer, etc, it may cause a ping at mid-throttle light loads. When the computer thinks the motor's getting EGR, it adds extra timing, which may cause a ping if you don't have functional EGR to lower combustion temps.
If you're thinking of getting headers, because you want headers, go for it. If you're only looking for a way to solve your linkage problem, just use the blazer's original manifolds...they should fit without a problem.
I'm afraid I don't have any experience with which to recommend any particular header for you, but I'm sure someone else here does.
Old Mar 13, 2003 | 11:53 PM
25THRSS's Avatar
you can get rid of it with no problems if you also get a custom chip that gets rid of the egr. Without the chip you will have the problems mentioned above.
Old Mar 14, 2003 | 12:05 AM
72Blazerod's Avatar
Thanks for the info. I have to get the chip burned anyway because I need to get rid of the VATS too. Is there any other system that I should be aware of when I am getting my new chip burned?
Rod
Old Mar 14, 2003 | 12:13 AM
25THRSS's Avatar
if your car has a top speed limiter you can remove that too
Old Mar 14, 2003 | 08:09 AM
black89ws6's Avatar
If it came from a vette, I don't think it would be speed limited
midge54
Dec 27, 2019 04:14 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
