everybody have heat shields on starter
Old Oct 16, 2001 | 07:00 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
hey i'm buying headers...just wanted to know if it is worth buying a heat shield for my starter.... also...i heard some guys switched to a smaller starter.....anyone have clearance problems..my starter is on the pass. side.... yay...
rob
Old Oct 16, 2001 | 07:18 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
hey rob, spend the extra ten bucks, it beats paying 50 for a new starter. plus make sure the headers dont touch it cuz it wil pinch it and wont let the thing spinout.
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Old Oct 16, 2001 | 08:30 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
If you want to solve the heat soak problem completely - get a remote mount starter solenoid kit. Summit sells one or you can just go to the parts store and pick up a Ford fender mount solenoid and a battery cable that will go from the new solenoid down to the old starter solenoid. Then just short out the old solenoid with a piece of metal of some sort and you're done. The Summit kit comes with everything you need and also includes instructions if you are worried about figuring it out. There is also a Technical article on this modification on this site.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 17, 2001 | 03:59 PM
Car: 1983 Z28 Clone
Transmission: TH350
thanks guys ill check it out...
rob
3rd gen money
Oct 11, 2019 09:57 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
