Inspection time. What kind of cat do I need to get?
Old Oct 18, 2001 | 04:01 PM
Surreal86z's Avatar
Im not planning on keeping it, just for inspection this year. Im not sure of the prices on stock cat's, but the dynomax high flow's are about 150 bucks for a 3in/3out. If I went the highflow route, do I get a 2 way or 3 way? No air tubes btw. If i get a stock one, because i dont' have air tubes and I need 3inch, what are my options there?
Thanks,
Scott
Old Oct 19, 2001 | 01:55 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Car Sound. You should have air tubes on there, so get a 3-way. If you dont, and your inspection doesnt need them, you can get a 2-way.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 19, 2001 | 05:37 PM
Surreal86z's Avatar
yeah, it "should" have air tubes and a pump, but I'm not going through state inpsection. It's just to pass the state regulations for emissions. It's gonna need some tuning to, but I'm hoping it passes. If not, it's gonna be a real headache to find a sticker in NJ now.
Thanks for the info,
Scott
Old Oct 19, 2001 | 10:28 PM
Dan87IROC-Z's Avatar
Yes, get a 3 way 3" in/3" out from Catco, it will cost you about $110 from Summit.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
mud runner
Nov 2, 2015 07:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 20, 2015 06:59 PM
Camaro_383
Sep 11, 2015 11:28 PM
Stryker412
Sep 7, 2015 09:11 AM
