aluminium tubing ?
Old Mar 18, 2003 | 02:01 PM
mat89RS's Avatar
aluminium tubing ?
My dad works on a machine that fusion/weld 1/8 aluminium sheets and makes 3inch aluminium tubing out of it.
Can aluminium be used for building exaust system ???
Will this last ?
Old Mar 18, 2003 | 03:48 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i rocks constantly beat on the alluminum it might punch a hole in it sooner or later. not my first choice for the type of metal for an exhaust system.
Old Mar 18, 2003 | 08:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
good chance it may melt, too. On break in of my cam my entire exuast was glowing red from the lack of airflow around it.
Old Mar 19, 2003 | 05:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I dunno if that would be a good idea... aluminum gets very soft at a relatively low temperature... like the temp of the exhaust system... so it could get really soft when it warms up to running temp and that could cause alot of peoblems.
Old Mar 20, 2003 | 02:00 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
how do heads last with the heat inside the exhuast ports?
yeah they have coolant running through them
but is that the only thing that keeps them from going?
Old Mar 20, 2003 | 12:00 PM
Car: 88 Camaro SC
Engine: SFI'd 350
the aluminum is a very good conductor of heat and the heat transferred from the exaust gasses is carried away and absorbed by the coolant going through the head.
Old Mar 20, 2003 | 05:38 PM
Air_Adam's Avatar
The heads last because the aluminum is much much thicker and isn't really put under the same "bashed around" conditions that the exhaust is. And the heads have coolant running through them, the exhaust does not. The heads also have the somewhat cooling intake charge of air and fuel to help them keep cool.
Old Mar 21, 2003 | 12:45 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
oh with the fuel/air mixture
was refering to the exhuast ports rather then the inatke ports
myself just wish I could use a titanium exhuast but I can't
what can I use that handles high heat and is light weight?
Old Mar 21, 2003 | 01:24 AM
Shpook's Avatar
Nickel :P Stainless steel is the next best under magnesium IMO. Did I say magnesium? I meant titanium. Hmm...Magnesium and heat...not a good combo. Anyways, the alloy and procedure it would take to make an effective aluminum exhaust system would so extremely outweigh the performance gains that the manufacturer themselves probably wouldnt buy it.
But, I'm happy with 3" mandrel-bent stainless steel.
Old Mar 21, 2003 | 08:23 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If your engine was running right it wouldn't get that hot. However AL melts at 1100 deg F & certainly will warp at lower temps than that. Carbon steel or stainless is your best option, unless you got the bucks for titanium.
Old Mar 21, 2003 | 11:33 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
lucky bastards.... run titatium
but yeah your motor shouldn't be making the exhuast glow red unless something was wrong.... like a lean mixture or retarded timing.
Old Mar 21, 2003 | 04:37 PM
Car: 88 Camaro SC
Engine: SFI'd 350
no... it was running right and wasnt going lean/ firing late. It was at night in the pitch black darkness of my garage that i saw this, though. So it wasnt exacly glowing brightly, just a real dim crimson glow.
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
