Weird Exaust problem (I think)
Old Oct 23, 2001 | 03:11 PM
mat89RS's Avatar
Just bought a v6 third gen for 50$, it's a 5 speed and it looks like a Firefly would kill me of a start.... for some reason the car is really really under power, i can't go faster then 90 km/h ... and I don't know why but if I run it for a little while the cathalic converter will be red as a cherry ... what the f**k is that ??? clutch seems alright and motor seems alright. the engine is shaking alot when it's on idle ... what shall I do ???
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
Old Oct 23, 2001 | 03:31 PM
88firebird305's Avatar
WOW you have an LT1 powered V6 getting 300hp.
My guess is cats cloged?
What engine is in it carb, FI? I guessing your sig is from about a different car?
Old Oct 23, 2001 | 05:10 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Also if the cat is glowing the car could be running lean, if I remember correctly.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 24, 2001 | 12:54 PM
mat89RS's Avatar
I got an 89 with LT1 that I installed myself, I just bought this v6 for 50$ mainly for parts...but it is still working .
LT1 POWERED
HEADMANS HEADERS
Old Oct 24, 2001 | 01:00 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
running lean? no i always figured it was too rich and the gas that did not burn in the cylinders burned in the exhaust which can cause popping sounds and turn headers and stuff cherry red. also due to a sticky valve or way off timeing
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Old Oct 26, 2001 | 08:31 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What ever the problem is you've go raw fuel
in the exhaust and the cat is trying to burn it off. Look to ignition first
Timing, plugs, wires, cap, rotor, coil etc.
after that check the fuel system. The cat will fail if you don't correct the problems soon.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
