how to test for pressure when deciding to replace CATS or not...?
Old Oct 30, 2001 | 07:22 PM
j166a99's Avatar
hey fellas,
what can i do, or where can i go to test for pressure to see if i need to replace my catalytic converters or not.
thanks...
'86WS7
Ram Air...
*EiyseWhite*
Old Oct 30, 2001 | 07:41 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
to test to see if the cat is clogged you remove the o2 sensor and see if it revs better, i have no idea about flow checking.
late model 91 rs, fully loaded, auto, t-tops, red leather, paint- gm red and yellow blend (light red), custom painted 16" Camaro rims
305 tbi flat base 14"x3" with K&N, hypertech chip, accel super stock plug wires, only use full synthetic oil and delco filter, 2 1/2" cat delete pipe, Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: New v-6 stang, 96 v6 camaro, totally killed '86 SC Camaro (305), 91 z 28 with 305
15.854@87.57 (I think I could have it 15.5 with good tires and two more runs)
next month: rest of ultimate tbi
Old Oct 31, 2001 | 08:32 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The manual specifies to replace the O2 sensor with an adapter and pressure gauge, then run the engine to cruising rpm and record the reading. I don't have the number with me right now, but there's a threshold that indicates a restricted exhaust.
TheExaminer
Aug 26, 2015 04:59 PM
BurlyChev
Aug 16, 2015 09:08 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
novaderrik
Aug 10, 2015 12:44 PM
