Cat question
Old Mar 25, 2003 | 05:14 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
Cat question
i got a "high flow" cat when i got my exhaust work done at mieneke. i put it in quotes because i dunno how that translates to a aftermarket cat but it was mieneke's performance cat so im assuming its higher the the stock flow one. anyway, im pretty sure when they installed the cat that the bottom was silver/chrome in color. now a few weeks later, the bottom have is dark in color, but the top is still silver. is this a sign of a engine running bad or do they change colors like that usually?
Old Mar 27, 2003 | 02:52 PM
TekViper's Avatar
Engine: 3.1L v6
anyone?
Old Mar 27, 2003 | 09:38 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
They do change colors. Keep in mind that almost all aftermarket cats are "high flow". This only means they flow more than stock. The color change should be normal but check timing just in case. Nitrous cars with the timing retarded heat the cats up big time. Cats only cost you about 3 to 5 horse if they are in good condition.
Old Mar 28, 2003 | 02:47 PM
TekViper's Avatar
Engine: 3.1L v6
i could touch the cat with my hand after about 30 minutes of the car being on driving around, is that a good indication that its running right or does it have to be running longer to see a problem?
Old Mar 28, 2003 | 07:44 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
No that's long enough.
chazman
Aug 28, 2018 03:25 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
