the best way to install edelbrock headers on 305 tpi ?
Car: 85 z28
which way is the best way to install the headers. and is there anything special that i have to do ?
hey dude you're pretty close to me. i'm in orlando. and i got the same headers as you. only thing that was a pain in the *** was the driver's side. i had to disconnect the motor mount and raise the engine a bit so the header would clear the steering linkage. other than that it went pretty smooth, just a lot of **** to remove and install back.
Car: 85 trans am
Engine: 79 4 bolt 350
you may want to try putting them in from the bottum 1st before you go pulling the motor mount but alot of people on here had to do that to get the drivers side in. headers are a pain but they are worth it adn its not too bad if you just have some patience and try all the ways you can to get them in the easiest. different ways work for different people. my flowtechs just dropped right in, about an hour job removing and installed all the stuff. good luck
Car: 85 z28
WELL IVE BEEN TALKING TO ALOT OF PEOPLE AND THEY ALL SAY LIFT THE ENG AND ITS ABOUT A 5-8 HOUR JOB I HOPE ITS NOT THAT LONG
Car: 85 trans am
if they are shorties then you shouldnt have to lift the engine. you should be able to fit them in from either the top or the bottum. i dont dought it takes that long if they dont just slide in from the top. its a pretty long process but you just have to be patient.
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
slip em in from the top. I would say it probobly takes longer to get the old exuast outa there than it does to put the new in. Driver side you dont have to remvoe anything but hoses, pass side you need to remvoe air diverter box and probably all your air conditioning stuff.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Both sides go in from the top. Drivers side you need to disconnect the steering shaft first. Its easier to do if you remove everything from the valve covers up.
Sanjay
Aug 12, 2015 03:41 PM
